question on downpipes
Old Mar 11, 2008 | 03:38 PM
Taz34SS's Avatar
Pics of the OEM exhaust with Parts numbers from the mufflers. This was taken off my 2007 Monte Carlo SS back in June.
Old Mar 17, 2008 | 08:59 PM
kissmyss03's Avatar
r u guys buying new gaskets for the downpipe or useing the originals?
Old Mar 17, 2008 | 09:16 PM
Taz34SS's Avatar
I brought a new one from Curt. The cost for a new one wasnt that bad.
Old Mar 17, 2008 | 09:30 PM
Count of Monte Carlo's Avatar
Actually I think these mufflers are from the far east... I forget where it's stamped but its says FUTABA on the mufflers....Last time I checked that was a japanese company that made remote controls for little R/C cars...so unless they delved into automotive mufflers or its a completely different company, Flowmaster definatly had nothing to do with the stock exhaust but I will give you one though, the MonteCarlo Nascar..behhh..... I think has Fowmasters on it, not sure if they are 40's, super 40's, etc.....
Old Mar 17, 2008 | 09:34 PM
kissmyss03's Avatar
ok so everyone has heard the exhaust systems crackle when u rev the car and it has no resinator. if i put on a catless downpipe and different muffflers but keep the resinator, you think it will crackle at all when reved?
Old Mar 17, 2008 | 09:36 PM
98Jeep360Limited's Avatar
It probably wouldn't crackle much with that setup. I think the resonator has more control over the crackling then the cat does, but I could be wrong.
Old Mar 17, 2008 | 09:38 PM
Taz34SS's Avatar
when i put mine on along with my res removal pipe, it will make alittle crackling noise, but not too bad.
Old Mar 17, 2008 | 11:25 PM
Semper91-RS's Avatar
So, here's what I'm doing (It's listed in my sig) Kooks Aero Chambers and a 3" O/R downpipe. I know someone here has a similar setup, so could you tell me, how does this sound? Is it raspy at all? I know it sounds hollow (All LSx blocks do..) which I like, but what is key is whether or not it's raspy. Also; I've figured out how to get rid of that damn annoying exhaust change you get when it drops into 4cyl mode.. Drive around in 3rd.
Old Mar 17, 2008 | 11:50 PM
fotoboy's Avatar
Lol not made in middle east /\
Old Mar 18, 2008 | 01:13 AM
Zero Rasp. It sounds like stock but much louder.
Old Mar 18, 2008 | 08:01 AM
BuffaloSS's Avatar
Taz...your wife let you bring that thing in the house and half-*** put it on a sheet on the carpet? What a woman! Although, it was relatively clean
Old Mar 18, 2008 | 08:55 AM
  #32
Taz34SS's Avatar
Yes she did. Infact, she picked it up from the shop that installed the maganflow system and carried it up the 3 floors to our apartment at that time. It only had I believe 30 miles total on the system.
I LOVE HER...!!!!!
Paul, Ill post a vid of my system for you to listen to. ITs a hogan high flow cat downpipe, res removed and the magnaflow cat/back, here is the video. I tuned my car this one time so I could rev higher then stock. It will sound kinda bad at first but when you drive it, it sounds great:
Old Mar 18, 2008 | 08:11 PM
  #33
kissmyss03's Avatar
it sounds good, but i will keep the resinator on so it doesnt crackle when i rev it. im debating over geting flowmaster 44s or the magnalfow cat back . but a catless downpipe is already for certain
Old Mar 21, 2008 | 11:33 AM
  #34
07gxpgray's Avatar
I am selling my downpipe i have used it for 2 months anyone interested... 75 shipped!
http://www.wbodystore.com/grandprix/...-v8-p-219.html
Old May 25, 2008 | 01:45 PM
  #35
LS4 swap's Avatar
Do you need to tune the ecm or will it work with the factory settings?
Old May 25, 2008 | 02:13 PM
  #36
SSWS6's Avatar
Sorry but I don't understand your question. Tune the ecm for an aftermarket cat-back? No you don't. Now if you install an aftermarket O/R DP you will throw a code without O2 simulators. Does that answer your question?
Old May 25, 2008 | 04:00 PM
  #37
hexxLS4's Avatar
Why not the 40's? I believe they're louder. I def had no rasp until I removed the resonator.
And as far as 3 inch piping goes, I know if you're not using forced induction, the 3 inch pipes will make you lose low end torque in trade for high end HP. Not a necessarily a bad thing off a launch since we're so incredibly torquey on the low end out of the box and get no traction as it is.
Old May 25, 2008 | 05:43 PM
  #38
Nacho SS's Avatar
2 month old post?
