My turn for tranny problems
My ImpSS has been shifting funny for a while, but the dealer could never find any problems. Today after pulling into the driveway I noticed some drips on the driveway behind the car. I looked under the car and there was a puddle. I got back into the car and backed it up to see WTF was leaking. I left it running, got out, look under the car and saw it pumping tranny fluid all over the driveway. It's getting towed to the dealer tomorrow. Hopefully they can find something wrong this time.
mm today i looked under my car because my left rotor is making a weird vibration so i was going to switch the sides the rotors where on and switch the pads. Now let me add to the story , i changed my oil filter a few days ago and cleaned everything with brake cleaner "i do this so i know if theres any fresh leaks" while i was under there i noticed the oil pan was slightly covered with a film of something and on the corner was something getting ready to drip but no drips in my garage so its taken a while to work its way there. wiped it off and smelled it to see if i got the scent of oil can't tell what it is but i got further under the car and it looks like its coming from my steering rack??? very thick fluid ?? not sure but its leaky extremly slowly i cleaned it one more time to make sure it wasn't something that was just left over from when they changed out my ISS
It's a 2006 with about 25,000. The tow truck driver started it to back it onto the flatbed and it started shooting fluid all over again. Couldn't really tell where it's coming from, but it's either coming from the rack or a transmission line. He said he towed 3 ImpSS's to the same dealer with trans problems in the last 2 weeks. I think mine's probably the rack instead of the tranny because it sounded like the power steering pump was starting to run dry.
I guess I should back off the visual mods and do some general maintenance then, huh Gonna have the dealer do the tranny fluid soon to make sure they notice any parts of my tranny in the pan.
I have noticed with my Impala SS that if I put it in first gear and manually shift into second under full throttle, there is a jerk before it shifts. It will do this every time, even when shifting well before redline. I took it out today for the first time in months and it seemed to be doing the same thing even when in D or OD. When it shifts at redline, there is a slight jerk during the 1-2 shift. Has anyone experienced this????
There is your first problem, your driving an AUTO and trying to Manually shift it???? Not smart. Its an automatic for a reason, leave it in D and drive
Buff, make sure they just drop the trans pan, replace the filter and replace the fluid. Also have them do the dexcool aswell.
Since I have a custom tuned car, I do not need to "DROP" it into gear. My car will go down into 2 or 1st with the COMPUTER doing it. Last time I checked, these are not full race cars, but when I do go, all I see is thier headlights in the mirror.
Now I remember why I dont miss Ft. Wayne all that much.
Oh, and BTW if you really wanna race someone, just get your car tuned and then we will talk.
Did you know you can leave your car in 1st gear and the computer will shift it into second while the stick is still in first???
ITS AN AUTOMATIC, DRIVE IT LIKE ONE...!!!
Oh, and BTW if you left your car in 3rd you would be alot better off then doing what you are now because your trans is only going to take so much before it pukes on you.
And yes, I did know it will shift itself from 1-2 by itself. I posted that last week!!!
Yes IT IS an AUTOMATIC but if your driving skills are such that you need the CAR to do the driving for you, why don't you buy the Lexus that can even park for you!!! Sounds right up your alley!!!!!!!!!!
Your car is going to shift when it wants to, not when YOU try and tell it to.
IF you wanted a car you can REALLY shift, why didnt you buy a Manual from Nissan.??? That should be right up there with your class in Ft. Wayne.
Keep up the crying, as I can hear it all the way down here.
