2700 miles and it is in service for trans issues
Old Apr 2, 2008 | 05:48 PM
kissmyss03's Avatar
Default 2700 miles and it is in service for trans issues
yup. at light throttle it slips going into 2nd and has harsh shifts. yey
Old Apr 2, 2008 | 06:52 PM
mike690003's Avatar
That sucks paul!!
And the one you leased and beat on gave you no problems.
Go figure...
Old Apr 2, 2008 | 07:06 PM
98Jeep360Limited's Avatar
That sucks, wonder what the problem could be. You'd think at 2700 miles nothing could really be worn out yet. There is a TSB out for the 2nd gear clutch causing slipping/ shuddering at light to moderate throttle, maybe have them look into that.
Old Apr 2, 2008 | 07:37 PM
mike690003's Avatar
Well, at 240 mile my trans went nuts. It was shifting rough and the "check engine" liight came on. After a long diagnostic, it turned out to be a frayed wire shorting itself on the outside of the transmission.
Old Apr 2, 2008 | 11:05 PM
Taz34SS's Avatar
Paul,
sorry to hear about your 07... Makes you wonder how the hell your 06 never gave you any problems. Maybe ask the dealership if they still have it and have them replace your trans with the one from your 06?
Old Apr 3, 2008 | 06:44 AM
kissmyss03's Avatar
u know what i think. i beat on the blue one from day one. i was aggressive with it. this 2006 i babied like you couldnt believe. only went WOT maybe 3 times in the first 1,000 miles. i would take off from lights very soft. after they fix this. im putting in shift kit, tune, and driving like i drove the other one
Old Apr 3, 2008 | 10:45 AM
Count of Monte Carlo's Avatar
since its affecting all gears it's most likely somthing is wrong with the VB. Could be somthing clogging up a passage or a bad piece of electronics. Looks like yours is comming out too..
Old Apr 3, 2008 | 11:58 AM
hexxLS4's Avatar
Or maybe it's a problem with the torque convertor
Old Apr 3, 2008 | 12:54 PM
kissmyss03's Avatar
well they are replacing the 2nd clutch pack i guess. i get it back tomorrow
Old Apr 3, 2008 | 02:12 PM
Mels SS's Avatar
Sorry Paul on the Trany issues. Did you get your headrest?
Old Apr 3, 2008 | 02:30 PM
BariPlayer's Avatar
I'm in the same boat-- my '07 SS has 9700 miles, and I have taken it in at least four times for tranny issues. In my case it's an issue of a noise and vibration with minor wheel shake that ramps way up at 45 MPH, levels off, then it picks up volume from 90 MPH onward. It is not dyno tune related either, as this was going on before the tune and to me it sounds like a bearing going bad about 6" to the left of the car's centerline. At any rate, the dealer has said it is a tire issue and has tried four wheel alignments on their Fred Flinstone machine ("Thag use rock, make wheel move!!"), inspected the suspension three times, replaced one rim, replaced the intermediate shaft, consulted a ouija board, driven the car at over 100 MPH on the freeway at my behest, and sacrificed a goat to read its entrails all in an effort to isolate the problem. I finally bought a set of 17" OEM rims/tires off of a fellow board member here, had those rebalanced by someone else, and had a 4-wheel alignment done again this time on a Hunter machine JUST SO I can go back to the dealer and say, "Sorry guys, but as I've been saying all along, it's not a tire issue."
Why don't service advisors listen to car guys like us who know WTF they're talking about?? After spending all day listening to dimwits and MILFs in their Suburbans and Tahoes try to ask for a simple oil change ("My husband says I need to have the oil thingee replaced...") you'd think guys like us would be a breath of fresh air to them.
Just call me "Cactus", 'cause I can get miiiiighty prickly.
Old Apr 3, 2008 | 02:36 PM
Sint3k's Avatar
I've experienced this **** all to many times. I had my 02 monte carlo in for transmission service 9 times. Thats not counting how many trips it took to convence them there was a problem
Old Apr 3, 2008 | 02:38 PM
It wouldn't burn up for no reason...so I hope they know why it did that and correct it so it doesn't happen again...
If it disintegrated than thats a problem with the pack itself or the fluid....
Old Apr 3, 2008 | 03:14 PM
BariPlayer's Avatar
Old Apr 3, 2008 | 09:30 PM
kissmyss03's Avatar
4T65E Transmission 1-2 Shift Shudder at Light to Moderate Acceleration (Replace Complete Second Clutch Assembly)
Models: 2001-2004 Buick Regal
2001-2005 Buick Century, LeSabre
2002-2007 Buick Rendezvous
2005-2007 Buick Terraza, LaCrosse, Allure (Canada Only)
2006-2007 Buick Lucerne
2001-2005 Chevrolet Venture
2001-2007 Chevrolet Impala, Monte Carlo
2005-2007 Chevrolet Uplander
2006-2007 Chevrolet Malibu SS, Malibu Maxx SS
2001-2002 Oldsmobile Intrigue
2001-2003 Oldsmobile Aurora
2001-2004 Oldsmobile Silhouette
2001-2005 Pontiac Aztek, Bonneville, Montana
2001-2007 Pontiac Grand Prix
2005-2007 Pontiac Montana SV6
2006-2007 Pontiac G6 GTP
2005-2007 Saturn Relay
with 4T65E Automatic Transmission (RPOs MN3, MN7, M15, M76)
This bulletin is being revised to add the Saturn Relay. Please discard Corporate Bulletin Number 06-07-30-023A (Section 07 -- Transmission/Transaxle).
Condition
Some customers may comment on a 1-2 shift shudder at light to moderate acceleration. Typically, the throttle plate angle parameter is 12-20% at time of condition with vehicle speed of approximately 24-40 km/h (15-25 mph). The customer may describe the condition as slip or delayed shift into second.
Correction
Replace the complete second clutch assembly with service kit, P/N 24240561. Refer to the GM Unit Repair Service Manual for the year and model of the vehicle being serviced for the 2nd Clutch service procedure.
This service kit contains: Second Clutch Housing Fluid Seal Rings (613), a Second Clutch Assembly (617), a Case Cover (Channel Plate) Upper Gasket (430), and a Case Cover (Channel Plate) Lower Gasket (429). In addition to the content of this service kit, four other gaskets not included in this service kit will also be needed to complete the repair, a Control Valve Body Cover (Side Cover) Gasket (54), a Control Valve Body Cover (Side Cover) Inner Gasket (59), a Case Cover Lower Gasket (429), and a Case Cover Upper Gasket (430). These gaskets can be obtained by ordering service kit P/Ns 24206959 and 24206391.
Be sure to use ONLY the Second Clutch Assembly and Second Clutch Housing Fluid Seal Rings provided in this service kit. DISCARD the Second Clutch Assembly and Second Clutch Housing Fluid Seal Rings removed from the transmission being serviced.
Disassemble ONLY the Oil Pump Assembly from the Case Cover (Complete). DO NOT disassemble the Control Valve Body from the Case Cover. Remove ONLY the Case Cover-to-Case bolts to remove the Case Cover and Valve Body from Transmission Case AS AN ASSEMBLY . To access all Case Cover-to-Case bolts, it is necessary to remove the Pressure Control Solenoid Valve Assembly (322), and 1-2 & 3-4 Shift Solenoid Valve Assemblies (315A, 315B).
Important: This service kit does not contain the gaskets and/or seals necessary to service the Case Cover and Control Valve Body, if they are disassembled from each other. Please review the graphic above for Pump Body-to-Case (230), Pump Cover-to-Case (231), Control Valve Body-to-Case (377), Manual Shift Detent Assembly-to-Case (805), and Case Cover-to-Case (433, 434, 435, 436, 374, 379, 380, 384) bolt locations.
Notice: Failure to use the parts in the service kit as instructed will cause improper function, and possible transmission distress.
Parts Information
Part Number
Description
Qty
24206959
Gasket Kit, A/Trans Case Cover
1
24206391
Gasket Kit, Case Cover
1
24240561
Clutch Kit, 2nd
1
88861003 (1 qt - US)
88861004 (1 L - Canada)
Dexron VI Auto Trans Fluid
10
Old Apr 4, 2008 | 07:57 AM
BuffaloSS's Avatar
Thanks for the tech info, Paul. I'm going to use this to get my issues looked at closely. Does this happen ALL the time, or can it be a sporadic issue? I can't replicate it on demand, but it happens nonetheless.
Old Apr 4, 2008 | 01:36 PM
kissmyss03's Avatar
happened like once a day. trans guy couldnt even duplicate it but knew by the way i described it that it was this bulletin
Old Apr 4, 2008 | 04:18 PM
Tap Dat SS's Avatar
I understand your frustration. I am actually a service advisor at a Chevy/Buick dealership and the other guys I work with know jack **** about cars. You can tell them all you want when you know something because they still wouldn't know what you're talking about. All they know is what the tech tells them and if you don't have a good tech working on it you get screwed.
Old Apr 20, 2008 | 05:58 AM
DolfanZ28's Avatar
HMMM the bulletin says "light to moderate" acceleration mine is only at WOT. Otherwise it looks like a match.
