Getting Dyno tuned by Vince at Trifecta
My PB was a 13.96@98.5 last year and this year i'm stuck in 14.2's@99.8 with 2.2-2.4 60ft's! I think the flipped motor mount is causing my tires to get shocked and lose grip, plus the TMS keeps kicking in (power off of the line after a little wheel spin just cuts out and then back in!) the only other mod that I have done is a 3" down pipe.
Vince seems like a pretty cool guy and is very knowlagable. He was Mr. Johnny on the spot when it came to answering my questions!
I spoke to Vince at lenth today about getting my Monte tuned and he talked about how you wanted to know if he could tune you today or asap.
I cant wait to see the numbers your car puts out as I am 110% sold on Vince to tune my Monte Via his GT tuner. Vince also adjusted the torque management, the anti score protection, the 2nd to 3rd shift points, shift firmness and gave me a custom tune in M (tap shift mode) It seems as if us GXP owners have a lot more options in tap shift mode and yes the trans is a lot more aggressive in M! Vince also adjusted my fans and I can now rev my engine in park or neutral to 6200rpm.
Driving home was like driving a whole new car, the shifts are much more firmer and snappier. Everything just feels so different and man this thing builds massive speed after shifting into 2nd. In fact second almost feels like first all over again, but super smooth.
I will scan my dyno sheet and post it later. I will keep track of fuel mileage and head out to the track next week. If you have any questions feel free to ask.
I highly recommend Vince's services.
I have 19,000 miles and over 20 hard driven 1/4 mile passes (trans is holding up great!) I stomp on it a least 4 times a day and use tap shift all of the time. I'm not here to brag. My trans temp is usually 165 on the way to work in the mornings and at 215 to 225 coming home in traffic. When the trans fluid gets that hot my shifts become very rough and I can feel a one to second shutter. Sometimes I'll hear a clunk. Engine temp is over the half mark too. Way to hot.
I had my engine dyno tuned and had the trans shift points raised and the line pressure increased. The fans also come on a lot quicker and this car is now bad ***! My engine temp has not gotten any where near the half way mark and my trans temp has not gotten over 185. My shifts feel much more precise and firm, no more slipping shifts. We all know that a hot engine makes a hot trans and hot everything equals a loss in power and reliability. While I was getting dyno tuned my first run showed massive KR and a very lean fuel ratio. Too much heat and in 70 degree weather! I feel bad for all of you down south with a stock tune. I don't think that my trans would still be working in that kind of heat. I believe that heat is whats is killing our 4t65e's. Get a tune, a trans cooler, wrap up you crossover pipe, install a 180 T-stat and run a 1 to 2 step colder spark plug. Get rid of the heat!
I am really glad you got this tune done and now its posted on the website. I wouldve like to see maybe alittle more TQ added, but since all you have is a downpipe, then the added parts I have should make up for that.
My only other problem is that the weather here in Indiana changes season so we are hot right now through Oct, then it will cool off and then get cold, for winter. I will talk to Vince this week about my order and the things needed to do for this tune, but thank you for doing this and posting what you have gotten, as some of the other people who are looking for a solid tune now can use yours and should have some great results.
Its hard to say, 20% of your 275 is only 55HP, which only would about 335HP. Thats ******* awesome vs stock.
I did see the dyno graf on the website and it does show more HP and TQ the longer you went.
also was wondering how hot the tranny should get mines never been past 215 but i felt like thats pretty hot
