Look at this...
Old Jun 2, 2008 | 01:25 PM
EmersonHart13's Avatar
Default Look at this...
#08-06-04-033: Identifying Aftermarket Engine Calibrations 2.0L, 2.2L, 2.4L, 2.8L, 2.9L, 3.0L, 3.1L, 3.2L, 3.4L, 3.5L, 3.6L, 3.8L, 3.9L, 4.2L, 4.3L, 4.4L, 4.6L, 4.8L, 5.0L, 5.3L, 5.7L, 6.0L 6.2L 7.0L, 7.4L, 8.1L Gas - (May 30, 2008)
Subject: Identifying Aftermarket Engine Calibrations 2.0L, 2.2L, 2.4L, 2.8L, 2.9L, 3.0L, 3.1L, 3.2L, 3.4L, 3.5L, 3.6L, 3.8L, 3.9L, 4.2L, 4.3L, 4.4L, 4.6L, 4.8L, 5.0L, 5.3L, 5.7L, 6.0L, 6.2L, 7.0L, 7.4L, 8.1L Gas Powered Engines Only
Models: 2006-2009 GM Passenger Cars and Light Duty Trucks
2006-2009 HUMMER H2, H3
Excluding Pontiac Vibe, G8, Chevrolet Aveo, All Saturn and Saab Models
Important: This bulletin applies to Gas Powered Engines ONLY. For Diesel Powered Engines, refer to Service Bulletin #08-06-04-006A.
If a suspicious hard part failure is observed in the engine, transmission, transfer case or driveline, perform the calibration verification described to determine if a non-GM issued engine calibration is installed. Non-GM issued engine calibrations subject driveline components to stresses different than the calibrations which these components were validated to. Repairs to transmission, transfer case and/or other driveline components where a non-GM engine calibration has been verified are not covered under the terms of the New Vehicle Warranty.
Instructions for Confirming Calibration Verification Number (CVN):
Go to TIS2WEB
Select "Calibration Information (SPS Info)"
Enter VIN
Select "Get Cal ID"
Select "ECM Engine Control Module"
Select "Next"
Select "Complete History"
Print
Take the printout to the vehicle along with the Tech 2®
Plug in the Tech 2®
Go to diagnostics and build the vehicle
Select "Powertrain"
Select "Engine"
*Select "Engine Control Module" or "PCM"
*Select "Module ID Information" or "I/M Information System" if module ID information selection is not available.
*If "I/M information System" was selected in step 15, it may be necessary to select "Vehicle Information" in order to display the calibration information.
Compare the calibration ID and Calibration Verification Numbers (CVN) to the Calibration Verification Numbers (CVN) on the printout.
* Steps may vary by controller.
Although the part numbers will be the same for each, it's the CVN that will determine if the calibration is GM issued. If ALL of the CVN's are EXACTLY the same, the calibration is GM issued.
If the part numbers match and ANY CVN's DO NOT match the printout, it is likely that a non-GM certified calibration has been installed.
If the CVN information is displayed as "N/A", it will be necessary to contact the TCSC to obtain the CVN information.
If a non-GM calibration is found to be in the ECM (CVN's on the Tech 2 do not match TIS printout) - In order to document the case -- a CLEAR digital picture should be taken of the Tech 2® screen showing the VIN and the CVN's that do not match the TIS2WEB printout. The picture, VIN and reason the vehicle is currently in for service should be emailed to JAY.DANKOVICH@GM.COM and STEVEN.R.BRIDSON@GM.COM for verification. Please copy your GM District Service Manager (DVM) on the e-mail. GM will verify if the CVN's are not GM issued and respond via e-mail within 72 hours.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2008 General Motors Corporation. All rights reserved
Old Jun 2, 2008 | 04:21 PM
kl_237's Avatar
If I'm reading that right, the jist of it is that tuners void the warranty? Correct me if I misinterpreted.
Old Jun 2, 2008 | 04:25 PM
Yes which is why you always reload your stock tune!
Old Jun 2, 2008 | 09:10 PM
BuffaloSS's Avatar
Good info, Emerson....Thanks. Answered many questions by some members recently.
Old Jun 3, 2008 | 11:22 AM
live2ride's Avatar
I wonder if the aftermarket tune leaves a "foot print" once the stock tune is restored. Maybe if the parameters are simply different would cause the build to be mismatched to the expected results.
Any techs out there have an answer?
So much for the burden of proof being on GM that the aftermarket tune has caused the failure.
Old Jun 3, 2008 | 01:11 PM
BuffaloSS's Avatar
I would think that yanking the ECM & TCM fuses and the neg cable after resetting the factory parameters would do the trick. Just explain to them that your battery died so the car hasn't yet relearned everything. Pretty sure the footprints would be washed away after that.
Old Jun 3, 2008 | 01:48 PM
06MonteSS's Avatar
LS1Tech Sponsor
nope... it stores checksums of the calibrations in other areas/modules that it checks...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Jun 3, 2008 | 02:21 PM
Taz34SS's Avatar
So, what would be the best action to take if you need to take your car in? Fry your ECM/TCM so they can not pull any data from it?
Old Jun 3, 2008 | 02:43 PM
05CherryGXP's Avatar
They do all kinds of stuff on the newer cars to be able to tell if you tuned them or not. My good buddy works for GM and was telling me some of the stuff. They'll hide stuff in places, like your Body Control Module having historical copies of your Engine Control Module in or Onstar checking up on you abd beaming stuff back to the mothership.
A lot of the older vehicles aren't as advanced and if you swap out the ECM and TCM you're home free.
