sounds like a nascar!
Old Jul 7, 2008 | 09:06 PM
ucquality's Avatar
Default sounds like a nascar!
i just got my car back from the shop today, i got hogans down pipe and my 3 inch exhuast back to magnaflow mufflers. total cost was 560.00. I also got my 3 inch cutout installed (which sounds like a nascar). the muffs are definetly quieter than the flow 44's( a lot less drone). i find my self running thru my neighborhood in first gear with the cutout open. everyone turns there heads. i also took it out on the highway to see how loud it is, did you know our cars do damn near 60 in first? it sounds a little funy shifting because of the lag, i hope to get that fixed with a tuner. i will try and get a video posted tommorow.
Old Jul 7, 2008 | 09:18 PM
TiredGXP's Avatar
60 in first? What RPM are you shifting at? I'm doing 51 mph at 6,000.
Oh, and this thread is worthless without a sound clip
Old Jul 7, 2008 | 10:00 PM
Nacho SS's Avatar
60 in 1st....BS.
Old Jul 8, 2008 | 08:06 AM
ucquality's Avatar
i leave it in first with tap shift.. within a couple mph's. sorry, i edit the post for the critics.(look up) i will get sound clips after work.
Old Jul 8, 2008 | 08:37 AM
Sint3k's Avatar
Originally Posted by Nacho SS
60 in 1st....BS.
He said almost and its true. I drive around in first too because of my cutout sounds mean as hell.
Old Jul 8, 2008 | 09:17 AM
ucquality's Avatar
when you let off the gas in first around 50 mph ... it sounds like you should be on the drag strip.
Old Jul 8, 2008 | 11:25 AM
Sint3k's Avatar
yea i love it only thing i don't like about it is when i'm in traffic with the cutout its very loud @ 2 grand so its loud as hell and your barley moving lol but when u open it up its 10 times louder and ur off like a bat out of hell.
Speaking of cutout my QTP has stoped working again and im busy fixing my cadillac right now so i wont be able to look at it until wen or so. I hope if i get another cutout i can use the wiring i've already done for the QTP cause it was a bitch running the wiring. Did you wire yours urself or wha ? and if you did where did you put the switches ?? pictures ? video ?
Old Jul 8, 2008 | 02:35 PM
ucquality's Avatar
here is the pic of the cutout. i got the wireless controller. i just ran the wire up threw the gromet under the spare tire. i wired the control box into the same ground and power as my amp. everything was right there.
http://s75.photobucket.com/albums/i2...t=MOV02869.flv
Attached Thumbnails sounds like a nascar!-dsc02866.jpg   sounds like a nascar!-dsc02867.jpg
Old Jul 8, 2008 | 06:24 PM
Nacho SS's Avatar
Thats why you should get a DHM cutout.
Old Jul 8, 2008 | 06:27 PM
Justin00SS's Avatar
Yep. I got a dmh.
Old Jul 8, 2008 | 07:20 PM
ucquality's Avatar
mines a badlanz
Old Jul 8, 2008 | 07:39 PM
Justin00SS's Avatar
I can't see in the pic but I reccomed going to autozone or checkers and trying to fine one of those steel/aluminum exhaust flange gaskets.
My dmh kept sticking from time to time. These gaskets are an exact 3" circle and now my dmh works perfectly.
I suspect that some people premature cutout failurs are due to this rubbing and it burns out the motors.
Old Jul 8, 2008 | 09:00 PM
ucquality's Avatar
there actually is a gasket, its hard to see.
Old Jul 8, 2008 | 09:08 PM
kl_237's Avatar
I'm another satisfied owner of a cut out. I love the way it sounds open, but I agree it can get kinda obnoxious after awhile. I was a cheapskate and got the manual one. Just takes about 5 minutes to get under the car and take the cap off.
Old Jul 8, 2008 | 09:32 PM
my06gxp's Avatar
Do you notice a loss of low end power with the cutout open??
Old Jul 8, 2008 | 09:46 PM
Justin00SS's Avatar
Mine had that rubber gasket too. This is a steel gasket to add some clearance.
Old Jul 8, 2008 | 09:55 PM
Sint3k's Avatar
I noticed when i first started riding around with the cutout open i didnt push much into the throttle much because it was so loud so this might simulate the assumption of powerloss but after compairing closed open i noticed 0 diffrence :-\
Old Jul 9, 2008 | 05:20 AM
ucquality's Avatar
i think i gained a little back from my previous setup. with the cut out open and and you nail the throttle, you can bake the tires off all day. i use the cutout around town and in my neighborhood. its fun too stay in tapshift mode and go from ligth to light in first... i love this thing. with my tuner, cai, i should get everything back i might have lost.
