How about a Z06 5.3?
Nice operating range, 210/218 duration with .531 lift. reasonable idle and a recommended operating range from 1000-6000 rpm. Probably not too different from a Z06 cam. The lift is compatible still with the dod lifters, just not a dod profile.
On a different note, someone in the G8 part of the forum is supposedly running a test DOD cam from Comp Cams. If this makes production, it would also fit the LS4. Might make a good cam for us.
Chip
I haven't seen any data on the valve opening or valve closing timing on any of the LS4's cam lobes, so I don't know if there is any duration/timing differences.
If anyone's pulling a cam out, it would be nice if you could slap on a degree wheel and dial indicator on and measure the opening and closing times (@0.050) on a dod and non-dod cylinder before yanking the stock cam. I don't think I'll be able to stick a degree wheel on with the engine in the car when it's time to do the rockers.
