valley cover
Old Jul 13, 2008 | 08:03 PM
CardinalsRed's Avatar
Default valley cover
i'm looking to buy the new weiand intake pretty soon and will need to change to an ls6 valley cover to fit the new intake. if i do that will that throw any codes and cause the engine light to come out?
Old Jul 13, 2008 | 09:03 PM
TiredGXP's Avatar
You'll most likely get a few DOD error codes, just have to turn those off in the tune at the same time you disable DOD.
You might want to consider plugging the oil passages that were used to send oil to the DOD lifters.
Gee, I wonder how many more months until that manifold is actually available to the public?
Old Jul 13, 2008 | 09:26 PM
DavidGXP's Avatar
Gee, I wonder how many more months until that ZO6 intake is actually on and working LOL
Old Jul 13, 2008 | 11:25 PM
TiredGXP's Avatar
Ha!
Maybe it's time to take a break from rust repairs on the Fiero's frame and work on the GXP again. I actually uncrated the Magnaflow catback yesterday and took a look at all the shiny new pieces.
I've got some vacation coming up in a couple of weeks, so that might be a good time to tackle the valve springs/rockers and exhaust.
Old Jul 14, 2008 | 04:33 PM
the weiand intake is on the market now
http://www.speedinc.com/newitem.cfm#C0000807
Old Jul 14, 2008 | 07:22 PM
DavidGXP's Avatar
Its too big for a 5.3 sorry!
Old Jul 14, 2008 | 08:14 PM
TiredGXP's Avatar
I take it you are referring to the 90mm size. I'd agree with that, 90 is more than these engines can really use. I suppose it wouldn't be too hard to make an adapter for our TB.
Notice that it also has the MAP sensor and brake booster fitting on the rear, won't fit on the LS4 since the power steering resevoir interferes with that (unless someone can figure out how to remote mount the resevoir).
Old Jul 14, 2008 | 09:12 PM
if you change to the ls6 valley cover it will work. and they have an adapter plate that you can use 78mm throttle body
Old Jul 14, 2008 | 09:53 PM
TiredGXP's Avatar
Yeah, it will work, but I believe their adapter is for the three bolt, cable-operated throttle body, which doesn't do much for our 4-bolt unit. A couple of hours, some aluminum stock and basic shop tools will let you build an adapter for our TB's.
Then you still have to deal with the clearance issue with the power steering.
Not trying to be a "wet blanket", just bringing up issues that need to be dealt with.
Old Jul 15, 2008 | 07:13 AM
you're right. so i would need a 90mm throttle body with a four bolt
Old Jul 17, 2008 | 12:37 PM
Mgpeagle's Avatar
There is a guy on the Gen 3 & 4 boards here that ports throttlebodies and intakes. He just did a LS4 for some guy. He usually nets 20 hp on the dyno when he ports LS1, 2, 3, 6's. I am sure the LS4 will be extremely close to those numbers and he charges 3 or 4 hundred bucks to port both. 20hp for 3 or 4 hundred bucks isn't bad at all. Eventually I will get an extra set for myself and have those ported.
-Mike
Old Jul 17, 2008 | 05:36 PM
good idea
Old Jul 17, 2008 | 08:16 PM
eddiemoney's Avatar
Well hook us up, i bet we could get a group purchase going
Old Jul 18, 2008 | 01:24 PM
Mgpeagle's Avatar
It took me forever to find this, but here it is:
https://ls1tech.com/forums/showthrea...porting+intake
Looks good to me.
-Mike
