hp tuner vs diablosport
It will allow you to do pretty much anything you need, except tune for that MAF....I'd put the stocker back on even if you go with HPt, unless you really want to spend some time trying to dial in your tune...
Thanks
Mike
If you select the no DOD tune the only thing you will notice is shift feel will feel a bit flat or delayed due to the TM being removed from the PCM.
HP tuners will allow you to talk to the PCM/TCM and set much more but you will need to either know what you are setting or have someone help (I'm sure there are plenty of folks who will) with what things should be set to at least for a starting point.
What ever path you take, enjoy!
