Drag Radials
Old Jul 31, 2008 | 08:35 AM
Pauls325's Avatar
Default Drag Radials
im looking at mt drag radials but they dont have the exact right size the closest they have is about an inch smaller in diameter how much will that affect my final drive ratio? and ill probably have to make sure traction control is off while im using them
Old Jul 31, 2008 | 08:56 PM
wnyimpala's Avatar
I run 255/60/16 d/r's on my impala. My 60" and 1/8 mile improved, but I didn't gain anything at the top end. These tires are 26" tall if you can find some that are closer to 28" tall you should be in good shape.
Old Aug 1, 2008 | 12:20 AM
Pauls325's Avatar
do gxp and ss have the same size discs in the front in not sure if 16s will fit on my machine or not
Old Aug 1, 2008 | 12:25 AM
StealthV8's Avatar
16's wont fit on a GXP the brake rotors are too big, 17" is the smallest you can go, without changing the rotors. i wonder if you can use the rear rotors up front since they are smaller
Old Aug 1, 2008 | 12:59 AM
Pauls325's Avatar
theres a new idea! we will see im really not in the market for any parts right now i have to go back to school in less than a month so im just hopeing that the aftermarket gets a little better for these things by spring
Old Aug 1, 2008 | 04:06 PM
JC05GXP's Avatar
Rotor swap wont work as you still have the caliper and mounting bracket to contend with. Changing the rotor wont change the height of the caliper. You'd need to swap it all out. Maybe brakes from an 05 GP would work but you'll loose a bunch of stopping power.
Old Aug 1, 2008 | 05:48 PM
Count of Monte Carlo's Avatar
255 50 16 Mickey Thompson E/T Street radials here. They are pretty good to drive on and hold up at the track.
Old Aug 1, 2008 | 11:26 PM
StealthV8's Avatar
Rotor swap wont work as you still have the caliper and mounting bracket to contend with. Changing the rotor wont change the height of the caliper. You'd need to swap it all out. Mayne brakes from an 05 GP would work but you'll loose a bunch of stopping power.
ya i was looking at the brakes today and the front caliper is way to big for the rear rotor..
Would we have to swap anything else over other then just caliper and rotor from a normal GP? like hoses or mounting brakets?
Old Aug 2, 2008 | 09:14 AM
JC05GXP's Avatar
You'd need the caliper, bracket and steering knuckle I believe. Hoses can stay.
