Cutout location?
Old Aug 13, 2008 | 10:53 PM
Red03GT's Avatar
Default Cutout location?
So I've got my cutout here waiting, and I just bought some tips and the hogan DP which should be here on Friday. I was looking under the car and I wanted to place the cutout as far back as possible before the Y split to the mufflers. It doesn't exactly look easily accessible for quick capping/uncapping. Where did you guys place yours? I think I might have to order my DMH electric valve sooner than I thought.
Old Aug 13, 2008 | 11:28 PM
Aaron_Provost's Avatar
mine's located before my cat
Old Aug 14, 2008 | 05:07 AM
ucquality's Avatar
right before the split
Old Aug 14, 2008 | 07:03 AM
Sint3k's Avatar
Kinda off the subject but kinda not. I'm getting ready to put this lateral arm into monte and need to remove the exhaust to remove the crossmember. I havn't really got a chance to get under it enough to see where its possible to remove the exhaust. Anyone know if this is possible with regular tools ? I got a glimpse of where the cat meets the rest of the exhaust and it looks like pressed bolts.
Old Aug 14, 2008 | 09:41 AM
EmersonHart13's Avatar
Anybody put it before the cat?
Old Aug 14, 2008 | 11:02 AM
yes, mine is before the cat
Old Aug 14, 2008 | 01:09 PM
IMPALA SS 07's Avatar
ive got mine right after the cat
Old Aug 15, 2008 | 08:56 PM
07MCSS's Avatar
My installer said that it should be after the cat. I leave my spare at home when I go to the track. It takes a little less than 10 minutes to pull the jack, raise the car, uncork and put the jack back up. PITA! Electric would be much nicer.
Old Aug 16, 2008 | 09:22 AM
radorider03's Avatar
I put mine right before the y. It fits nicely between the rear lateral links.
Old Aug 17, 2008 | 01:12 PM
LeadFootGXP's Avatar
I put my cutout before the split by the pass. side rear wheel. Near the front of the straight part of pipe on that side. It dumps right infront of the rear wheel and it avoids any clearance issues as far as speedbumps and things go
Old Aug 18, 2008 | 03:25 PM
ucquality's Avatar
thats were mine is and it works perfect!
