Lateral arm finally fixed!
Old Aug 20, 2008 | 07:56 PM
Sint3k's Avatar
Default Lateral arm finally fixed!
Well i finally repaired the bent lateral arm. After getting the Chilton manual i finally broke down and decided to start taking apart the rear suspension. Everything went fairly easy. Had to make a few stops at auto zone for some more deep sockets and a better quality torque wrench sence i forgot mine in Indiana. Has anyone messed with the rear suspention is there anything i should be cautious of after reassembly ? Was excited to finally get it done and tell everyone so i don't have pictures yet. Should have them uploaded in a few hours.
Old Aug 20, 2008 | 11:13 PM
MonteSS8707's Avatar
Just double check all bolts you removed and re-installed after driving it about 25 miles. Make sure to get the alignment checked. Anytime you replace bent suspension parts it will affect the alignment. Other than that you should be good.
Old Aug 21, 2008 | 08:24 AM
BuffaloSS's Avatar
'bout damn time. We're discussing suspension upgrades right now @ NAIOA...but for the non-SS models, and after digging up your initial thread, it got me thinking about if you ever fixed that.
Specifically, we're talking about the BMR products.
Old Aug 21, 2008 | 01:03 PM
Sint3k's Avatar
I looked at the BMR's and the size is bigger but where its adjustable the threads are smaller then the threads on the oem arm. So i'm guessing there is the weakest point.
Old Aug 21, 2008 | 02:29 PM
BuffaloSS's Avatar
Interesting. I'm getting a ton of clunking around back there...I need to get under and start yanking on stuff to find the loose parts. It's probably endlinks again...but it could be any of the other bushings, too. Time for poly upgrades!
Old Aug 21, 2008 | 10:08 PM
06WHITEMCSS's Avatar
Might be smaller diameter, but what grade is it? and the more threads there are the better clamping force, meaning fine threads are better than course threads.
Old Aug 21, 2008 | 10:10 PM
If your going Poly get ready for a rough ride, rubber is way softer, but get em, and find out how rough it is, and let us know if its tollerable!
Old Aug 22, 2008 | 08:10 AM
BuffaloSS's Avatar
Yeah...I know. My car is a mess now with the bad struts and possibly springs, plus the 20's...so I figure if I can go Poly while replacing the struts/springs they might not be as noticeable.
