Powersteering question
Old Aug 24, 2008 | 09:55 PM
98Jeep360Limited's Avatar
Default Powersteering question
Does anyone else here notice high effort steering at low speeds? Every so often, my car will act like it has no power steering when turning in a parking garage or something, then as soon as I bring the RPM's up it steers normally. What could cause this?
Old Aug 25, 2008 | 12:10 AM
4doorSS's Avatar
Dont know what causes it but mine does the same thing on occasion i checked the power steering fluid it was full so i dont know what it could be good to know its not just my car
Old Aug 25, 2008 | 12:17 AM
Nacho SS's Avatar
Yep I get this....I think its because the engine doesn't have enough RPMs to run the pump at the point. My monte is a bitch to drive especially in parking lots that are tight (school lot ) but it gives my arms a workout.
Old Aug 25, 2008 | 12:29 AM
Sint3k's Avatar
you should really only be noticing this when the AC is not running. When the ac is on it should bring rpms up high enough you don't have this problem. Our engines idle at aroudn 500 to 600rpm which apparently our pump doesnt like. If your having to much problem turning it just push the gas a little. But defiantly nothing wrong with it. Wish our cars woulda came with variable power steering
Old Aug 25, 2008 | 06:29 AM
Well I guess it's nice to know I'm not the only one dealing with this. I can't recall having this issue with any other car I've owned, but I guess I won't worry about it.
Old Aug 25, 2008 | 10:05 AM
BuffaloSS's Avatar
Yeah, I've thought that the pump is way undersized from be beginning...that or the pulley just isn't small enough. With the 235's it was bad...but now with the 255's it's even worse trying to parallel park.
Old Aug 25, 2008 | 06:17 PM
So the dealer would probably tell me this is considered normal operation if I were to complain?
Old Aug 25, 2008 | 06:53 PM
05CherryGXP's Avatar
It never hurts to ask man, under warranty = only costs you your time.
Unless the dealer can find a leak or a slipping belt or something though all they can do is shrug and say "Normal operation."
Never noticed a problem on my GXP, must be a Impala and Monte quirk.
Of course us GXPs have our own quirks to make up for it.
Old Aug 25, 2008 | 08:12 PM
impala06ss's Avatar
Not exactly true. Not wanting to start lip but I have had dealers many times screw up something unrelated while fixing something else. Not always but it does happen. Get your car back with scratches, dings, etc.
Also, if it really bothered you about the power steering issue (and yes, I have it too and its always when I don't expect it) I think the thing to do would be to install a pulley slightly smaller than the existing power steering pulley. This would slightly speed the pump up, probably enough to prevent it from happening again. Wouldn't have to be very much smaller, if it's like mine it's already on the verge of problem free, just not quite.
Old Aug 26, 2008 | 02:00 PM
4doorSS's Avatar
Ive never really paid attention when the ac is on it doesnt really happen alot to me but like the other guys say usually in a tight situation it gets a lil hard to turn but it doesnt bother me enough to go sit for hours at my dealer for them to tell me theirs nothing wrong even though its still under warranty
Old Aug 26, 2008 | 02:26 PM
BuffaloSS's Avatar
Does the engine whine at all? If it whines, it could be a pulley or pump issue, too. They replaced a few pulleys of mine b/c they were whining like a biotch.
