Sanity check before ordering STB
Old Sep 30, 2008 | 09:39 AM
dennisL's Avatar
Default Sanity check before ordering STB
I'm new to this forum and wanted to thank you guys for sharing the info posted here. I've been driving muscle cars since the 60's but the 06 Impala SS is my first front wheel drive car that has any *****. I'm really enjoying it (but still getting used to the torque steer).
I did my research on the STB addition and think I'll just do the rear bar for now. Before I place the order, I would like a sanity check from the experts as some used DonRome brackets and some used ZZP.
For an 06 Impala SS rear STB, do I order the bar from GMPP (p/n 12498648) and the rear brackets from DR Customs?
Old Sep 30, 2008 | 10:37 AM
20SS07's Avatar
Yes. And if you choose to get the front bar you will need the front brackets from DR and the modified front bar from DR as well.
Old Sep 30, 2008 | 12:08 PM
neilownz's Avatar
Don isnt selling the modified front bars anymore. You have to email flip.
Old Sep 30, 2008 | 01:21 PM
dennisL's Avatar
Thanks guys. I just ordered the rear bar and brackets. After I get it installed I'll make a decision on the front.
If I do the front, it sounds like I'll have to purchase another bar then send the bar to Flip for the mod. It would be much simpler if I could just order a modified bar from him but I understand.
Thanks again.
Old Sep 30, 2008 | 01:25 PM
20SS07's Avatar
I wasn't aware that it wasn't going through Don anymore, it's been a year since I got mine. Does Flip still have bars that he modifies? Or do you have to supply your own now and send it to him? After having the rear in you probably won't notice much more difference with the front. The rear is what makes the big difference in these cars.
Old Sep 30, 2008 | 04:05 PM
JC05GXP's Avatar
Don just recently stopped carrying the front bars through his site. I haven't asked him why. I don't think FLIP has them on hand right now, but will modify the one you actually send.
Old Oct 1, 2008 | 08:19 PM
07carlocrusader's Avatar
this is true I just installed mine a couple of weeks ago from don and flip!! But now you have to purchase the bars, send em out to him and he'll modify them for ya!! He does a execellent job on them!!
Old Oct 27, 2008 | 10:10 PM
ckso226's Avatar
I'm wondering if anyone can help me with an stb question. That's why im rehasing an old thread and not making a new one.
So i ordered both strut braces from GM parts direct p/n 12498648 and noticed that it didn't come with the brackets. I looked over at one guy's profile and saw that he is using the same strut braces as i am, but just painted. Anyone know where the brackets are from??
Heres the link: ITS the LAST PICTURE
http://www.naioa.com/v2/modules.php?...ehicle&CID=274
If no one knows, can anyone tell me where to get compatible brackets where there is no drilling involved??
Thanks.
Old Oct 27, 2008 | 11:38 PM
neilownz's Avatar
don rome. http://www.drcustomparts.com
Old Oct 28, 2008 | 07:23 AM
20SS07's Avatar
You do realize that a regular bar directly from GM will NOT fit the front, right? You need the modified one from the above mentioned website. The standard bar will not clear the alternator on the V8 W-bodies. If you look closely at mine, you can see the notch in the bar where the alternator is. The only way you get the regular bar to fit is if you use ZZP brackets, which are higher, but then you get some hood bulge.
Old Oct 28, 2008 | 08:52 AM
06MonteSS's Avatar
LS1Tech Sponsor
Yes, Don IS selling the front bars again... can get everything right from his site...
http://www.drcustomparts.com/Prices.htm
get the whole package for $185. last item in the list on that page...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Oct 28, 2008 | 09:20 AM
ckso226's Avatar
Does the don rome front bar require drilling?
Is the rear bar also the standard gm bar or will it not fit?
Thanks for the info btw.
Old Oct 28, 2008 | 09:25 AM
06MonteSS's Avatar
LS1Tech Sponsor
no drilling required... they just bolt right on...
the rear bar is the GM bar, no modification required for that one, but you still need the brackets Don sells...
__________________
Old Oct 28, 2008 | 09:30 AM
20SS07's Avatar
Yep, as 06MonteSS mentioned, the standard GM bar is fine for the rear. The brackets both front and rear just bolt in using the existing bolts on the strut tower, and then the bar bolts to your brackets using the included hardware.
By Brett Foote | 2026-06-04 05:00:17
