AEM BOSCH UEGO Dual wide band o2 sensor system
[COLOR="Red"] Sold [COLOR]
I have the following UEGO wideband O2 system for sale...
Unlike the 30-4100 system available for Under $200 on E-bay. This is a DUAL system. If you wanted to run a dual system any other way, it would require TWO of the 30-4100 systems and TWO guages to read/mount.
I installed this system in my C6Z06 but I stuck with the stock ECM/tuning so I'm not able to adjust fuel by bank.
The system includes the following...
Part# 30-2300 Dual Channel Wideband UEGO Controller Module ($600 new)
http://www.aempower.com/ViewProduct.aspx?ProductID=842
Part# 30-4213 UEGO Controller "Display" 0-5V AFR, Silver Bezel/Black Facehttp://www.aempower.com/ViewProduct.aspx?ProductID=318
Part# 30-2001 Bosch Wideband UEGO "Replacement" Sensor
http://www.aempower.com/ViewProduct.aspx?ProductID=624
The system was installed last August and was used for approximately 5,000 miles. Everything is in working order. The only part you need to supply is the mounting cup for the guage. This system also allows you to have a direct variable output to your lap top for real time tuning.
The stock 30-2300 system only comes with 1 UEGO sensor. This package includes the 2nd sesnsor AND the specific 30-4213 guage used to monitor it along with all the wiring and set-up instructions.
Combined retail for these items is over $800. I'll take $425 shipped in the USA via fed-ex insured shipping. I accept paypal. Please e-mail me at bowtiguy@comcast.net with any specific questions.
The guage itself will only display one channel at a time, but you can unplug UEGO sensor #1 and plug in the other to display other UEGO sensor #2. The standalone systems plugs DIRECTLY into the back of the guage so you can't swap from one sensor to the other easily. The laptop output of this system is two channel so you can read both at the same time. Hope that helps!
