Clarion DXZ785usb cd player 728 colors to match dash JL Audio 13w1 Vert T-top sub box
I have a like new Clarion Dxz785USB cd player.
I used it only a few times, as the car isnt my daily driver and is going through
performance transformation.
I bought this stereo for one reason.
It matched my firebird dash lights absolutely perfect!!
Looks stock !!
You can even adjust the intensity, contrast of each color to match the brightness of your dash lights!
Aside from the above features it has on screen Ipod control (no adapter needed...through your ipods usb! XM and Sirius satellite ready, bluetooth ready,cd changer control,steering wheel controls,motorized detachable faceplate with hard case.If you have a monsoon syteem, no worries, it will easi;y hook up to the monsoon amp and speakers through a simple wore harness. This is the same inexpensive harnes you ned to hook up any aftermarket radio. If you have an aftermarket amp, youll love the 6 volt pre-outs (rcas) with subwoofer control. Has front,mid,high electronic crossovers (fully adjustable,defeatable). It also has selectable eq's, as well as an "All seat feature that helps make up for poor speaker placement. Ipod sound enhancement,etc,etc. You can defeat the internal amp if using an aftermarket amplified system for cleaner sound. Below is a list of specifications.
I was a certified car audio installer for many years. This item is like new!!
Comes with a wireless remote,faceplate hardcase, instruction manual,all wiring,Plastic dash install kit (secures stereo behind dash bezel) and my tech support!!! All thats needed is a wiring harness (about $9.00). This is needed when installing any aftermarket radio. This wiring kit goes from the radio wiring and plugs directly into your factory radio harness, so no cutting off factory plugs! I can set you up with one. If you are replacing an aftermarket radio, you already have one! I will sell you my wire harness for $15.00 as I will have to uninstall and re-install it.
I paid $299 plus shipping. $180 shipped Paypal and its yours!!
PAC SWI JACK steering wheel control interface for sale @ $30.00 retail $75 SOLD
CEA-2006 Compliant Yes
RMS Power Output 18 watts
Peak Output 53 watts
RMS Power Bandwidth 20-20kHz
Preamp Outputs 6-channel
Sub Preamp Outputs Yes
Preamp Voltage 5.8 volts
Display Color 728 Colors
Key Button Color Variable
EQ Bands 3
Sound Shaping Type Digital Z-enhancer
Wireless Remote Yes
Steering Wheel Control Compatible Yes
Security Detachable face
Flip-Down Face Motorized
Expandability
iPod Connection/Control Built-in audio
AUX Input Rear
USB Input Rear
Memory Card Slot USB memory
A/V Inputs No
Bluetooth Compatible Optional
Satellite Radio Ready Both
Navigation No
Changer Control Yes
Tuner
Tuner Type Not given
FM Sensitivity 9 dBf
FM Presets 18
AM Presets 6
European Tuning No
Seek/Scan Seek
Radio Data System No
Playback
CD Frequency Response 5-20kHz
CD Signal-to-Noise 87 dB
CD-R Playback Yes
CD-RW Playback Yes
MP3 Playback Yes
WMA Playback Yes
AAC Playback Yes
DVD Playback No
JL Audio 13w1v1 4 ohm Subwoofer box for 93-02 VERTS and T tops
This box was professionally modified to fit my 2001 convertible.
Fits like a glove!
Will work great for t-tops as well.
Like new, used for MAYBE 1 hour.
Monster Cable subwoofer wiring installed in box.
Poly fil installed in box.
Woffers secured using t-nuts so can be removed without sacrificing
tightness of the bolts.
JL Audio grills (retail $80.00) also included.
Top of box (all that will be seen) is covered in GM black felt. Very durable!
Sides and bottom sprayed with black undercoating, but can be capeted over. I saw no need.
Most amps can be screwed to the side of the box, hiding them from view.
Box is completely sealed inside. Used foam gaskets to seal woofers.
This box POUNDS!!!
Sits VERY snug in the rear well No need to secure. Will not move.
Box is 5\8" MDF with correct internal volume for these woofers.
Paid $580 for this set up.
Sell at $300 picked up.
Will seperate woofers at $180 (with grills) shipped
Cannot ship box Local pickup only as I dont have a box to send it in.
Looks stock !!
EQ Bands 3
Wireless Remote Yes
Expandability
AUX Input Rear
USB Input Rear
A/V Inputs No
Navigation No
Changer Control Yes
Tuner
FM Presets 18
AM Presets 6
European Tuning No
Seek/Scan Seek
Playback
CD-R Playback Yes
CD-RW Playback Yes
MP3 Playback Yes
WMA Playback Yes
AAC Playback Yes
DVD Playback No
Fits like a glove!
This box POUNDS!!!
