Built 346Boost Motor,Spearco A2W cooler,Built 8.8 rearend,Radiator
Have a LS6 346 Built by erik down at HPE
shortblock consists of : Callies Compstar 6.125 LS1 Rods W/ARP 2000 Rod Bolts
ARP 234-5608 Main Studs
Weisco K392A01 LS1 25cc Pistons 3.905 Bore
Total Seal Piston rings plasma moly
Block was honed with Torque plates,lined honed main bores,balanced rotating assembly
Federal Mogul 152M 3/4 Groove Main Bearings
Clevite CB 663 H rod bearings for 2.100 SBC Chamfered Race Bearings
Stock Prepped LS6 Crank
Comp Cams 228/228 116
Had a set of stage 2 TEA 5.3 Heads and jsut had them freshened up they have 2.02 Ferrera/1.60 Incolonel valves,multi angle valve job,manley ls1 valve springs with titanium retainers heads flowed 321 at .600 lift
6.0 GM MLS Gaskets and ARP 12 PT head studs
oil pan tapped with 10 an fitting for turbo oil return line
all this is brand new never run i decided on going a different route and need to sell it i will sell all the accesorries and such too(alt,alt relocation bracket,water pump,valve covers) with it the motor is 8:4:1 C/R perfect for lots of boost-looking to get $6500 obo with everything
Spearco A2W intercooler-Handle 1000-1100 rwhp-$700 obo
Grififn Radiator P/N 25241(Brand New)SOLD to black98ws6
Chryo Treated 4l80e with yank cross member,trans cooler,yank 3400 stall-$2300 obo
8.8 Rearend stock length,just freshened her up has 31 spline moser axles,cobra trak lok with carbon clutches,4:10 gears,new bearings,will leave the backing plates and reluctor rings on it and let it go for $1700 obo with aluminum driveshaft and lakewood lower control arms
TCI LS1 Flexplate-$150 shipped
