Power Glide tranny, Lifters, Nitrous Cams and some more
Yes. I had to modify it for the 4" stroke so its had some bends in it on the oil control areas and also on the front where the rods got close to the pan. but it will fit a 4" stroke good now. since its modified ill take $250 Shipped. If you want ill leave the 10AN fittings in the pan for the remote filter. I was going to have them welded in so they don't come loose when your putting the lines on and off but never got aroundt to it. Ill also sent the 2 special bolts you need for the back cause the long stock bolts won't work.
PM me if your intersted. i check tech just about every day but not this post that often.
how much does your car weigh? i am interested in the 408 cam, and just wanted to get a guestimate of the outcome if i put it in my car. mine is in a fox that weighs 2760 w/driver and 4.10's with a 1.80 glide
