getting a coil...what one??
Old Oct 13, 2008 | 06:36 PM
96capricemgr's Avatar
Originally Posted by 94CamaroZ28SS
I recently installed a MSD blaster coil and had problems with the car missing and stuff, i called MSD and told them that i could see no arcing off the wires but they were stock wires, i did notice a constant arcing on the coil and MSD said that that was static discharge which is normal they also said to replace my wires with better ones that could be the issue. I bought a set of 10.2 MM wires and installed them with NGK TR55 plugs and coated the MSD with a little bit of dielectric grease and now the car runs like a champ!
I like the MSD coil when i installed it the throttle response is much crisper and the car seems to have more power!!
Just a thought, don't you think the new wires/plugs could be responsible for the perceived increase. You replaced worn parts with new.
Old Oct 13, 2008 | 09:22 PM
ThoR294's Avatar
8 coils is the only coil upgrade i will do
Old Oct 13, 2008 | 10:05 PM
94CamaroZ28SS's Avatar
well the throttle response was before i replaced the pugs and wires!
And yes now the car feels even better with the new plugs and wires and she purrs like a kitten! the coil doesnt arc anymore either!!
Old Oct 13, 2008 | 11:27 PM
jarretthise's Avatar
like i said before i love it on my car but i will go back stock if i ever ahve to change it
Old Oct 13, 2008 | 11:35 PM
bluelt1z28's Avatar
I have a MSD coil for 4 years, no problems
Old Oct 14, 2008 | 03:47 PM
buffman's Avatar
even the stock coil has that glowing coming from around the frame. That being said my 12+ yr old stock coil is still going strong. The MSD coil is too. I recently purchased a new one, and I like the new design better... Lower resistance too.
Old Oct 14, 2008 | 06:23 PM
lt170chevelle's Avatar
thats one thing i want to ask...everybody that has had problems with other than stock coils...did you even upgrade the wires to something with low resistance.. i am sure its harder on a higher voltage coil trying to send voltage through a high resistant wire like the stockers or even worst..autoparts brand lol
