My exhaust options?
Initially I was going to get a 3" to 4" ypipe as I have a 4" bullet laying around.
Not sure if I should go that route, or sacrifice ground clearance, not sure how much clearance I will lose though honestly. Well lets post some pictures.
So yeah, I'm can't make up my mind. I thought about just dumping a bullet off of each collector, but well there isn't enough space to do that between the collector and the subframe connector on the driver side. So I'm contemplating Hpiping it after the collectors, then losing some ground clearance to mount two bullets right behind the diamond part of the SFC's, you know making the hangers there like we see on a lot of dual setups. I wonder how much ground clearance I will lose though....... or if I should stick with the single 4" route dumped, but I'm not sure I have the torque arm mount that will work with that either, although I did see if the 4" bullet fits between the mount and the floor of the car and it does.
i went with a single 3 pretty much inthe stock location. ill try to find a better pic but i just took a U. cut it in half turned it and welded it on after the cat. a 4" is pointless unless the Y pipe merges into a 4" pipe. unless you modify the Y pipe for it. then a 4" wouldnt be half bad
3" off the Headers Y'd to a 4" section that I made, then narrow's down to a 3.5" with that Cut-out, then to a 3" over the Axle into the Muffler. It's really high-flow. It clears the ground well too, the lowest point is that damn Cross Member.
BTW, this is before the Cross Member got ripped off..
I guess I can judge better once I have it back on the ground, its tempting though to hpipe it behind the trans crossmember and then do the dual bullets, I guess there is the downfall of the double diamond subframe connectors, most people with duals do not have them, and thus don't have the issue I'm looking at.
I think I will stick with the single 4" dumped idea, anyone out there have a 3" to 4" ypipe for sale?
Merv you said you made yours, do you have any up close pictures or what you used?
People say all the time that they made their own 4" ypipe but seem scared to post up what they used for parts or where you can get them. I know I don't want to pay the price Mufflex wants. To this day I still can't find the flowmaster 3" to 4" merge.
I already have the 4" bullet, so I guess if I do 4" dumped all I need now is to figure out the ypipe and find a 4" turndown.
It's just a piece of 3" that was cut inhalf on a slant, then welded together in a "V" Then I cut the end of it off to mate into a 4" piece, I cut it to where it overlapped by probably a 1/4" so it still have alot of flow, then welded it to the 4". Basically it's a perfect 3" to 4" Y-pipe.
I love the sound, and I love the stance. I don't know which to get rid of. Not the sound because that is performance oriented, so most likely the springs.
D
By the way my sig pic is prior to true duals...
http://www.flowmastermufflers.com/pr...oducts_id=3696
Thats all I see on their page...
Its getting tempting to order those ebay one chamber knockoff and just run them dumped off the collectors. I'd do bullets cause I love those, but I don't think I have enough space on the driver side before I hit the SFC, perhaps if I cut the end of the bullet off and weld the turndown to it, it could possibly fit.
Any real downside to no H or X pipe?
I'm thinking of running 2 1/2" duals if the clearance will be decent. Summits Hpipe kit is under $50 as are the 2 1/2" bullets. I figure I might be at $200 in supplies for the whole exhaust. What should I use to reduce it off the headers, and how should I attach it to the Pacesetters?? I don't want to weld the setup to the headers, I'm tired of cutting exhaust when I have to take it off.
What seals better a butt or a lap? I suppose I should use a lap style, get a header reducer that will slip over the end of the header?
Look in my pic, you can see mine, I have 3 of them. The 2 in the front are 3", and they are banded around the Y-Pipe, that's flared so it slips over the Header Collectors.
The one in the back is 3.5", and that's directly over a cut that I made so I can drop the whole Exhaust System when I'm pulling the Transmission out. It's just banded around the Pipe with the cut in the center of it, and it doesn't leak at all.
Anyone on here got a 2.5" h piped bullet setup? I wonder what it sounds like. Hopefully badass.
Decided screw the single 4" plan, no one on here seems to have one for sale, and the damn 4" turndown is $60?!!!! So yeah going the duals route, I guess screw ground clearance. Well at least I went 2.5" instead of 3" maybe I won't sacrifice it all.
Yeah well with the double diamond SFC's I couldn't even dump single chambers off the collectors, so I guess eating up ground clearance it is.
With the 4" the ypipe would have been expensive and the 4" turndown is stupid expensive also. I guess I'll have a new 4" bullet for sale soon.
