biggest cam for stock stall and spring????? HELP PLEASE!
Old Oct 14, 2008 | 08:01 PM
2001AntiVenom's Avatar
Default biggest cam for stock stall and spring????? HELP PLEASE!
i did a little searching nothin much but i need to know the biggest cam you can put into a bone stock motor with stock stall and stock springs. if there is any diff its a corvette motor thanks alot i dont know much about lt1s i know ls1s. Its a friends car. please help and where can i get one
Old Oct 14, 2008 | 08:05 PM
92camaroguy's Avatar
For the springs stock is it. And where can you get one what?
Old Oct 14, 2008 | 08:11 PM
a cam. You cant go any bigger on stock springs. In ls1s you can
Old Oct 14, 2008 | 09:13 PM
BOLO's Avatar
Like mentioned above, you can't put a bigger cam with stock springs and /or valvetrain. You can install a set of 1.6 roller rockers(sa), with your stock springs, in fact,one of my first bolt ons.
96capricemgr's Avatar
Again stock. The stock cam actually greatly benifits from more spring and stall. Doing a cam now would be a poor choice. I say that after having done a mild cam with stock stall. So I am not pointing a finger, I am saying do not repeat a mistake I already made.
Old Oct 14, 2008 | 09:54 PM
SoxXpupPeT's Avatar
springs arnt that exhaust and arent bad to install and theyll prevent valve float and your lifters from sticking. cheap insurance thats Needed
Old Oct 14, 2008 | 10:12 PM
StealthFormula's Avatar
X2
Been there done that, stall first, cam later. You will have a better driving car and a faster car with a nice stall over running the stock stall with any cam. It is 100% mandatory to change valvesprings when upgrading to any camshaft.
