Highest HP Hyd roller guys?
Old Oct 16, 2008 | 10:30 AM
OutlawZ's Avatar
Got another ? will 36lb injectors be good enough my tuner says its better to have them maxed out then going with 42lb injectors
Fire your tuner....... seriously......
tuneability with 42's versus 36's is going to be negligible... The 42's are gonna provide you alot more fuel and room to grow... don't buy injectors that are "maxed out" as your tuner put it.... cause if you want to change something and make a bit more power guess what you're buying 42's anyways.....
I'd really like to hear the info behind your tuners theory.... If you want to know roughly how much power injectors will support then here...
42lb/hr * 8 inj = 336 lb/hr * 2 (reverse engineering the formula from a BSFC of .5) = 672 HP......
So the 42's will provide enough fuel for ROUGHLY 672 hp...... This doesn't take into account duty cycles.... Only how much fuel THAT injector will support in a maxed out state..... 80% DC which is the industry standard shouldn't be exceeded by more than roughly 5%. If you're at 85% making power you need bigger squirters....
Old Oct 16, 2008 | 12:32 PM
flyinZ's Avatar
Yep, go with at least 42's..Thats what I've got, and doing just fine.
Old Oct 16, 2008 | 03:03 PM
darrell hoagland's Avatar
Originally Posted by James Montigny
Entirely possible depending on the cam used and if timing is
pulled in the tune to accommodate N20.
Brett beuer did my cam it is like 599/609 108 lobe seperation with 1.6 rockers dont remember the rest it sound bad ***.just gonna do a tune on motor my msd box will retard my timing for the n20
Old Oct 16, 2008 | 04:28 PM
James Montigny's Avatar
Originally Posted by darrell hoagland
Bret Bauer did my cam it is like 599/609 108 lobe seperation with 1.6 rockers dont remember the rest it sound bad ***.
Sounds like a Bret cam LOL The man does great work.
Duration is going to tell a whole lot more about how much fuel you will need than lift will.
36 SVO should be ok for most grinds, 42 would be a much safer bet.
Your tuner can tell you for sure.
That's an excellent way to do it.
Keep us posted on how it does both on the dyno and at the track.
It sounds like you have a very similar setup to what I am building.
Old Oct 16, 2008 | 08:06 PM
here is a sound clip of my car before i ture it down to put my new heads and intake on http://www.youtube.com/watch?v=82YY-pCrlZs
Old Oct 17, 2008 | 09:15 AM
fergymoto's Avatar
Great work of wearing out valvesprings VERY fast and breaking stuff. That's about all I've observed and experienced. The cars run fast for a little bit.
Old Oct 17, 2008 | 09:17 AM
If you're going to run aggressive lobes, you need proper springs and valvetrain components.
That's part of the deal and Bret will tell you that before you order.
Old Oct 17, 2008 | 01:27 PM
bombebomb's Avatar
Buy better parts, seriously.
