MSD Pro Billet Distributor. Likes? Dislikes?
My existing OEM replacement barely has 8K on it and looks great, I don't see any reason to
replace it for the new motor other than to add the venting "feature".
Motor is still outside the car at this point, so if I'm going to do it, now seems
like the time to take care of it.
My stock unit and semi-new cap/rotor are in good shape.
Unless the venting is a huge deal, I see no reason to change it.
I mean, if the opti dies due to gas buildup, I'm just gonna have to replace it. No huge loss.
Just a little more work to do it later than to do it now with the motor out of the car.
I had an msd unit, Bought it before I was a member here, before i was informed. after aproximately 10,000 miles, the optical unit fell apart. Not exactly a good investment for 5bills. On a stock, or relativly stock car, the delco opti is perfect, If you're winding the **** out of your car, 6500rpm+, you'd be better off making the investment on one of the "distributorless" systems.
The only advantage I see is moving the high voltage out of the opti.
And if I remember correctly, one of the distributorless vendors stopped making/supporting their products.
But yes, I certainly see your point about the MSD optical sensor you had being a poor design.
I'm in the process of building a 383 too but even then I see no need to rev the **** out of it, 5700-6000 is about all I need to go. On that note, I have two questions about the rpms: 1) Does a 93 have a rev limiter? If so what's it set at? and 2) What are the max safe revs for a stock bottom end 180,000 mile LT?
My 'current" opinion is diferent from when I bought the MSD unit. it 'should" be better than the OEM delco but my recent experience would not support that.
My 17k mi Delco unit is back in and no high RPM miss.
Shaft play appears to be the problem on the MSD I have. $111 service quoted from MSD
what ever unit you get, go vented
Dwayne;
not many. About 4k mi
rotor came off at 2k mi, reinstalled using lock tite. High RPM miss was present from beginning which was valve spring and aparently opti related. new valve springs solved the 'float" but a intermittant but distincet cut off then go again was going on. assumed it was ignition related so I pulled the MSD. Cap/rotor looked good, no signs of moisture but shaft had way more play than when the unit was new.
car would run fine, just break-up above 5500 "sometimes". Since there is so much play in the shaft I can see the rotor itself move so assume at high RPM's enough play for optical sensor to keep up allignment on the disc.
Since I bought the car new Optis have been a problem, mosytly due to "other" things. Like many my attempt to install what should be a better part in the end did not last.
I think we all agree the "Opti" from a design and build point certainly has flaws and the fact most of us are pushing RPM's beyond 5200 any brand has problems. I have disected both Delco. MSD and Dyna's unit. The later 2 try to address known weaknesses and appear to do a decent job at that but all have the same optical sensor, wheel. Interesting that the MSD bearing vs Delco bushing did not last.
we can make cars go faster...but often at a cost of parts.
#34
https://ls1tech.com/forums/lt1-lt4-modifications/930312-just-picked-up-msd-opti-would-you-like-my-opinion.html
Must have missed that one...
#36
I still run the stock GM AC Delco Opti with no problems...I have seen more people with issues with MSD over the years so I just dont think its worth it...Like Dwayne said earlier caps and rotors are maintenance items as they wear like any other cap and rotor...replacing them can be such a pain that most will never change them until they have a failure...I run my set up to 6500 rpm and have for 13 years with no problems...I did change out the stock opti for another in 2005 when I switched cams and had the heads re-ported...The genuine AC Delco stuff has worked well for me...
--Alan
--Alan
#38
What did you replace it with?
#39
I almost dread saying that I replaced it with the MSD unit. But, I bought the damn thing before I heard all this bad ****. I assumed (wrong might I ad) that when everyone else was upgrading the ignition they changed the opti over. I looked at another GM one, the Accel unit (that I couldnt find for a spline drive), and the MSD. I know, I know now that I have the feedback from all the much wiser LTX guys I'll know not to do that again if I can just go with an OEM. But I will say it is running a HELLUVA lot better.
