Unusual Problem
Old Oct 18, 2008 | 01:13 PM
mywhitez28's Avatar
Exclamation Unusual Problem
I have a 94 LT1 z28. I was driving home when the ABS Inop light started to go on and off, then the next day I was driving to work and the ABS light went on the air bag light continually were blinking. On my way home from work that day now in addition to those lights the Low Trac and Brake lights on the dash were continually blinking. I have never heard of anything like this before so I am hoping someone here will have some insight.
Old Oct 18, 2008 | 08:23 PM
csjta2's Avatar
Check your ground wires near the battery, I have seen these come loose and cause this problem. The ground wires come off the battery and bolt to the shock tower, this is where they come loose. HTH
Old Oct 18, 2008 | 09:18 PM
camar0corey's Avatar
Yep def. sounds like a loose/corroded ground. I was all sorts of freaked out when it happened, then felt kinda dumb when I found one of the grounds loose, which upon inspection had also acquired a sweet layer of rust.
Old Oct 20, 2008 | 09:33 AM
mywhitez28's Avatar
That did the trick, thanks for your help!
