lt1 trick flow heads
Old Oct 21, 2008 | 10:52 PM
nirvana1221's Avatar
Default lt1 trick flow heads
Does anyone have flow bench numbers for trick flow heads out of the box non ported compared to the darts. Im just trying to figure out what wond be the best bang for your buck thx
Old Oct 22, 2008 | 10:11 AM
TrickFlowTech's Avatar
LS1Tech Sponsor
Default Trick Flow numbers
Airflow Chart for GenX LT1 Street/Strip Cylinder Heads
Lift Value Intake Flow CFM Exhaust Flow CFM
0.100" 51 58
0.200" 136 98
0.300" 191 136
0.400" 230 163
0.500" 253 177
0.600" 254 190
Tests conducted at 28" of water (pressure); exhaust with 13⁄4" pipe.
__________________
Old Oct 22, 2008 | 10:34 AM
slomarao's Avatar
AI's TFS heads are close to 300 cfm's .600.
Old Oct 22, 2008 | 05:12 PM
So if i were to do a set of out of the box trick flows were would the best place be to order a custom grind cam? Also with those flow numbers what kind of power would i be making?
Old Oct 22, 2008 | 07:14 PM
borninatransam's Avatar
We ordered mine bare and with no additional porting and played with different valves and ended up getting them to flow 280 at .550". The head dyno'd decently out of the box but seemed to shine on 150 shot. One guy local to me had one with a mild cam and these heads and on the 150 shot he got 484 rwhp and 640 rwtq. The torque numbers speak loads for what these things do on the gas.
Old Oct 22, 2008 | 09:29 PM
fergymoto's Avatar
Was that torque number with a 6 speed or auto?
Old Oct 22, 2008 | 09:33 PM
6 speed.
Old Oct 22, 2008 | 09:45 PM
fergymoto's Avatar
Pretty nice!
Old Oct 22, 2008 | 10:01 PM
borninatransam what valves did you guys end up using? As far as the custom cam any suggestions
Old Oct 22, 2008 | 10:09 PM
1badzee's Avatar
Mine with swirl polished valves flowed 283cfm (out the box) @.600 - DART PRO 1's
Old Oct 22, 2008 | 11:03 PM
James Montigny's Avatar
You got 283 out of 180cc castings? or out of 200cc castings?
That's very nice for only having installed valves.
Old Oct 23, 2008 | 04:41 PM
PM sent. Let me know if I can help anymore.
Old Oct 23, 2008 | 04:42 PM
Originally Posted by fergymoto
Pretty nice!
Didn't realize that you lived in NC. Are you over on horsepowerjunkies any? If not check it out.
Old Oct 23, 2008 | 05:28 PM
fergymoto's Avatar
Haven't been before but I'll check it out sometime.
