starter problem
thanks
I took apart the starter last winter to see if it was worn out and to clean it up because I believed it was because of all the dirt and oil that had gotten on it, but the internals all looked to be in great shape so I just cleaned it up and still have the same problem.
When it happened to me all my dash light come on and when I attempt to crank, I hear a click but the starter doesn't come on.
On Friday I put it in Neutral, then back to park, and I thought that's what it was, but this morning it wouldn't start in N or P.
All of the sudden it started without a problem.
Next time it happens, I want to check it against this schematic to see if its the BCM, neutral safety switch, start solenoid or something else.
How often does it happen to your car?
This does resemble starter heat soak, but this happened on my stock 2002 SS, which doesn't have headers.
I notice mine will show a really low battery level on the gauge when it happens.
Voltage was showing fine with the engine off (12.8 volts) and 14 when charging. But I guess it couldnt deal with the load of starting the engine. Problem went away with a new battery.
