I hate my car, 2 Optis still no spark... WHY!!!!
I can get voltage to read them and the connectors look fine.
I have 12v on the pink which supposedly means the coil is bad and I have no pulsing ground on white black which supposedly means the icm is bad... I have fuel I can smell it.
Just no spark.
Just no spark.
Better not have its the new one from MadZ28. I put it in thinking maybe the other did but I am sure I found the issue now.
A local friend looked at his Trans Am (95) and we went over grounds etc and as someone told me and I just could not understand why they would have voltage.
These wires are a ground: (Two Tan w/White Stripe and a Black)
![](http://i62.photobucket.com/albums/h98/CrossGT6/SNC11275.jpg)
However they seem to carry voltage.
I did the test before and the black has 12V as soon as the car is turned on.
The Tan/ White has 6.5v when cranking...
So I am going to look at his or find pictures of someone elses to see how they should have been grounded since mine seem to have no connectors. Then I will copy it and try it and I am sure it will magically fire... and I will have to thank that member who told me they were gorunds and I just had a bad opti before.
