bad ECM/ECU
after that, i would turn the key on and they tack will do a crazy little dance then settle down. i try to start it, and it sounds like it is firing 180* off. it will go back and forth between those 2 things randomly... any thoughts? only thing i can think of is get another ecu. TIA
but will a bad ground allow it to run occasionally? also i can start it up and the tach wont be working.... i hold the rpm at around 3k, and then it will just shut off or it will go down to idle and barely run sounding like it is firing 180* off
