PITA to change oil pump on LT1?
Looks like its just below 185 degrees when the oil pressure is that low. IDK how the hell you managed to get that pan off with out lowering the K member. I had mine jacked up so high it was on the cowl and starting to bend it and i still couldn't get it to clear the trans.
They are Hella 2500 Optilux. Thats just the halo part when i turn them all they way on there really bright. They make my low beams even better but i aimed the as not to glare other drivers. I will send you a pm with some more pics i dont want to hijack his thread.
