400hp
Old Nov 3, 2008 | 01:52 PM
93TAJ.C.'s Avatar
Default 400hp
I know its possable to squeeze 400hp out of a stock bottom lt1. I just was wondering what cam to use, what headwork is needed, etc. Can someone help me with this? The motor is coming out this winter so im in need of advice. Thanks!
Old Nov 3, 2008 | 02:00 PM
LT1 > LS1's Avatar
unlimted budget:
big heads, big cam, LT4 intake
limited budget: (what I'm gonna do)
ported stock intake manifold, cc503 cam, and a 100 shot of nitrous. that should put down at least 425 whp. of course you need supporting mods for either budget.
or get a procharger
Old Nov 3, 2008 | 02:02 PM
Elliott's94Z's Avatar
http://www.elliottsportworks.com/lt1.html
Take a look at the LE2 package..depending on what cam you go with and the supporting mods you already have done you can squeeze 400+ with that Lloyd set up.
Old Nov 3, 2008 | 02:06 PM
LS1 SPEED's Avatar
I agree
Old Nov 3, 2008 | 02:33 PM
EliteCamaro94's Avatar
thats what im gonna go with, im also lookin to try and pull off the 400 hp out of my stock bottom end lt1.
Old Nov 3, 2008 | 03:00 PM
BlackTTC6's Avatar
400hp crank?
Long tube's
FIPK
230 Duration Cam
Good set of springs
You'll need heads for 400rwhp tho.
Old Nov 3, 2008 | 03:07 PM
SS MPSTR's Avatar
Do you want to simply say 400rwhp, or do you want it to ET well? Is streetability a concern? (probably have to define that term too). Can you afford to have it break?
Old Nov 3, 2008 | 03:08 PM
BlackTTC6's Avatar
Did i miss where he said 400rwhp?
Old Nov 3, 2008 | 03:17 PM
PNYKLR-TA's Avatar
whats FIPK
i always see that and have no idea what it is.
Old Nov 3, 2008 | 03:22 PM
BlackTTC6's Avatar
Originally Posted by PNYKLR-TA
whats FIPK
Fuel Injection Performance Kit
Old Nov 3, 2008 | 03:27 PM
SS MPSTR's Avatar
he really hasn't clarified it either way...
Old Nov 3, 2008 | 03:48 PM
James Montigny's Avatar
Ported heads / bigger cam + the basic bolt-ons are an easy route to 400rwhp N/A
and the bottom end will run just fine as long as you pick a sensible cam that peaks
in a usable RPM range. (something in the 230* duration range works well for our cars)
Nothing wrong with doing it using N20 or FI either.
In fact, a good well-though-out plan includes proper head/cam selection to match your long-term ambitions.
Old Nov 3, 2008 | 04:03 PM
OutlawZ's Avatar
good heads like a stage ii setup, port matched manifold with 58mm throttle body, long tubes, and a cam in the 230+ duration and .570+ lift range on a 112lsa shoujld get you real close.....
my 355 was built like this and was stock crank with a longer 6" rod.... but you could do almost the same thing with a 5.7" stock rod... my car made 422 RWHP in that config on motor..... so it was making all of 500 at the flywheel.....
Old Nov 4, 2008 | 09:09 PM
93TAJ.C.'s Avatar
I basically want a street warrior, something strong and reliable as it is my summer daily driver. I wont be hitting the track too often if ever. Im more into the handeling and just street performace. And no i cant afford to have it break, im not going to run a blower or nitrous though. I do plan on getting full cnc port and polish with 2.02 1.60 valves, pacesetter longtubes, my fipk, fully ported intake manifold and 58mm tb, holley 36lb injectors with hi flow rails air fuel pressure regulator. So my main questions are what cam, pushrods, rockers, or any other parts that need to be upgraded. Iv wanted to do this for years and have done tons of reading but now that its actually happening i see the gaps in my knowledge so all you guy's help is very appreciated....sorry this is so long
Old Nov 4, 2008 | 09:25 PM
slomarao's Avatar
LE2 all day. As long as you dont run a smaller cam you will have 400rwhp no problem. With the supporting mods everyone is talking about you could maybe hit 410, 415 rw.
But making that hp will come at a high rpm in a LT1. If you really cant afford to blow the shortblock i wouldnt do a cam, especially if your higher miles. Your just asking for it.
Old Nov 4, 2008 | 09:35 PM
chavez885's Avatar
LT4 hotcam!
Old Nov 4, 2008 | 10:56 PM
BlackTTC6's Avatar
Originally Posted by chavez885
LT4 hotcam!
WASTE. Custom cam will give better gains
Old Nov 5, 2008 | 08:25 AM
just talk to lloyd elliot he can explain to you what the best set up is as far as the cam and head package. I have read that his le2 package is very reliable.
Old Nov 5, 2008 | 08:48 AM
93TAJ.C.'s Avatar
Well i think ill be a little safer with the bottom because its getting rebuilt while its out. Probubly going to 355. But stock crank/rods
Old Nov 5, 2008 | 09:28 AM
PNYKLR-TA's Avatar
well in that case the only thing that really lacks the strength to hold rpm's is your rod bolts so if you get ARP bolts and a rebuild/refresh i'd say you can run the rpms up to about 6500 or so safely.
