Rocker arm studs?...
Old Nov 6, 2008 | 11:47 AM
97LT1's Avatar
Originally Posted by AChotrod
someone please tell me I ordered the right ones?
they should say for SBC. Your not going to find a trickflow LT1 specific guideplate. (these come close to LT1 spec/needs)
Relax, take your time. Look online for where to trim the valve covers. You will thank yourself for upgrading right the first time. It seems you never know how far you will go with a motor buildup in the future, and doing it this way you will not be buying parts over again to fit your build.
Old Nov 6, 2008 | 11:55 AM
ss.slp.ls1's Avatar
Too late. Anyone need aluminum 1.6 SA roller rockers?
AChotrod's Avatar
Sweet they are for a SBC the 5/16 size threw me off. I was thinking about the 7/16 rockers/studs and read they are for 5/16 pushrods. LOL! I Think im safe! I just hate returning stuff.
Old Nov 17, 2008 | 09:40 AM
ss.slp.ls1's Avatar
Get
Arp 134-7103 7/16 rocker studs $38
Comp Pro mag 7/16 NSA roller rockers 1305-16 $290
Trick flow guide plates 30400623-8 $16
Trick flow push rods 21407xxx $80
So were those the right guideplates for a LT1?
I will be ordering all of the above shortly and a CC503 cam.
Will the Crane dual spring kit 10308 handle a CC503?
Old Nov 17, 2008 | 10:32 AM
AChotrod's Avatar
Yes they were the right ones. Whats the spring pressures and cam specs? Dont feel like looking them up.
Old Nov 17, 2008 | 11:01 AM
ss.slp.ls1's Avatar
Summit says the spring rate is 408 lb/in.
Old Nov 17, 2008 | 11:16 AM
Formula350's Avatar
Fairly bad pic I found:
Here's a tad better one (I brightened it up a bit to help):
Old Nov 17, 2008 | 11:20 AM
ss.slp.ls1's Avatar
Do you only have to clearance one side?
Old Nov 17, 2008 | 11:25 AM
Formula350's Avatar
One side on EACH valve cover. I don't know which side, but I'd assume the back (closest to the intake) side, since the rear of the rockers are fatter than the fronts. Again, I don't know, so that's simply a guess.
Old Nov 17, 2008 | 11:33 AM
ss.slp.ls1's Avatar
Both valve covers...got it thanks. It is the side closer to the intake manifold, you can tell because the clearanced valve cover in the pic is the passenger side valve cover.
Old Nov 17, 2008 | 11:36 AM
Formula350's Avatar
Hmm yep, you're right heh I didn't think about looking closer at the first pic
