Rocker arm studs?...
Old Nov 4, 2008 | 04:12 PM
ss.slp.ls1's Avatar
Default Rocker arm studs?...
I did some searching and got answers going both ways. I am planning to run a cc503 with aluminum 1.6 SA rr's and crane gold dual springs.
Will this set-up work fine with stock studs?
Old Nov 4, 2008 | 05:28 PM
leadfoot4's Avatar
I'd put in a set of ARPs. It's cheap insurane and easy to do while the car's apart.
Old Nov 4, 2008 | 05:36 PM
GIZMO's Avatar
I agree the stock studs are a weak link at higher rpm's.
Old Nov 4, 2008 | 06:12 PM
Mighty Whitey's Avatar
I'd probably jump on the ARP bandwagon too..
then again, I'm running a comp 503 with 1.6 promags and older comp 918's with stock studs.
I've raced probably 200ppl on the street and 70 track passes, massive burnouts, and multiple trips to 6500+.
never had a problem in around 12k miles.
it's your choice, but I've never had a problem with mine with the exact same cam.
Old Nov 4, 2008 | 06:34 PM
ss.slp.ls1's Avatar
The stock studs are pressed in correct? How do you put the ARP's in? Do you have to tap the holes?
Old Nov 4, 2008 | 06:42 PM
Badazz 97 TA's Avatar
no, the stock studs on f-body Lt1 heads are screw in.
Old Nov 4, 2008 | 06:56 PM
Ls1Bait's Avatar
Yup and theres a touqh spec also just not sure what it is.
I also switched to ARP studs.
Old Nov 4, 2008 | 09:50 PM
96lt1m6's Avatar
i would ditch the SA rocker idea all together!
7/16 NSA rockers,7/16 studs,flat plates, hardened pushrods
Old Nov 5, 2008 | 12:10 AM
1badzee's Avatar
Dont the centerbolt valvecovers intefere with 7/16 rocker arms? Dont LT1s need a narrowbody rocker?
Old Nov 5, 2008 | 12:33 AM
96lt1m6's Avatar
the valve cover can be trimmed @ the support rail inside if needed,the use of narrow body rockers helps fittment. it's worth the small amount of modifacation.....
Old Nov 5, 2008 | 08:39 AM
1badzee's Avatar
So If you have aftermarket covers without the support rails, standard SBC rockers will fit just fine?
Old Nov 5, 2008 | 09:34 AM
96lt1m6's Avatar
yes,be sure to get taller valve covers for an Lt1 or you will have to do mods to the alternator(bottom) to clear.
Old Nov 5, 2008 | 11:22 AM
AChotrod's Avatar
Get
Arp 134-7103 7/16 rocker studs $38
Comp Pro mag 7/16 NSA roller rockers 1305-16 $290
Trick flow guide plates 30400623-8 $16
Trick flow push rods 21407xxx $80
Old Nov 5, 2008 | 11:33 AM
ss.slp.ls1's Avatar
Originally Posted by AChotrod
Get
That's what I was thinking, will all that fit under stock valve covers?
Old Nov 5, 2008 | 11:41 AM
kinglt-1's Avatar
No, you will have to clearance the inside of your stock valvecovers. Try a search, this topic has been beat like a dead horse!
Old Nov 5, 2008 | 01:24 PM
OutlawZ's Avatar
don't run stock studs..... I snapped a stock stud in half idling with a STOCK cam when all I had was bolt ons and 1.6 comp cams pro magnum RR's and ****....
thank god it didn't hang the valve open....
get ARP hardened studs.... and yes you will need to cut the inside of the valve covers...
Old Nov 5, 2008 | 01:42 PM
ss.slp.ls1's Avatar
Thanks fellas, you've been very helpful.
Old Nov 5, 2008 | 09:26 PM
AChotrod's Avatar
double check those guide plate #s! Sorry I think I ordered the wrong ones DAMN! SORRY!
well maybe not! Someone Help here!!!!!!!!!!
Old Nov 5, 2008 | 11:26 PM
AChotrod's Avatar
someone please tell me I ordered the right ones?
Old Nov 6, 2008 | 08:15 AM
leadfoot4's Avatar
50 ft/lbs. IIRC.
