exhaust pop... please read seemes abnormal
checked injectors with noid light. they all tested good, flashed on and off. it acts like the MAF is disconnected and when you throttle it motor. like it cant keep up with the air coming into the motor. any suggestiong?
put the regulator on today and still seemes to miss a little at idle. when the throttle is snapped it is very sluggish/ stumbeling and i can hear a popping from the intake. the motor seemes like an injector is bad. i proceded to unplug injectors individually and it seemed to really effect the idle and stumble more espically when i unplugged #1 and 4. when i plugged them back in it did not correct the stumble instantly but took a few seconds to clear up. could this be bad injectors?
