stickwith a built LTx or swap in built LS1
instead of dumping a ton of mods on a stock motor like heads cam and boltons im looking to go straight to dropping in a built turnkey longblock.
im wondering if its worth the extra hassle swapping in a LS series motor, when it seems like once you pass a certain price tag the lsx and ltx are at the same power levels
for instance
lt1 making 634/750 at letting out at 5200 on a 100 shot before the recent rebuild which should add some new power (70hp claims) for $7,000
https://ls1tech.com/forums/showthread...t+motor+engine
or this 408 making 550/505 n/a for $8,000
https://ls1tech.com/forums/showthread...344&highlight=
any reason i should drop the extra money on the LS plus all the extra money and hassle for all the time and parts needed for the swap
i am in the process of this myself,i really love the LtX but when it comes down to it dollar for dollar you CANNOT beat the LsX,just look at what stock Ls6 heads can do with a small cam! when finally added up both motors done the way i want them the LsX was almost 1800.00 less and almost 100hp more
sign of the times................. like i said if i was wanting a cam only car or just heads and cam car id swap in the ls1 put a ms4 in it and call it a day
but im looking at already built motors. as you can see in the links above the LT1 is just as good if not better than the lsx above for a thousand dollars less and minus all the pain of swapping over. and i have a tuner who can handle anything i can throw at him so the tunabilty isnt an issue
"convince me why i should spend the extra couple thousand on an LS1 and all the pain swaping it in. vs over a built LT1 making the same power"
lol easy terms :
LTx making 600 rwhp= direct swap right back into the car no hassle and cheaper
LSx making 600 rwhp = buying ls1 k member, steering rack, computer, all the wiring etc. plus the added cost
convince me why i should chose the ls1
I owned several of each over the years, I think the lsx would make more power with the same mods then thr ltx. A decent size cam only lsx with a 150 shot could get you 600rwhp. Theres tons of cam only lsx putting down 400+ to the wheels. Then again a properly built ltx could put donw some serious #'s as well
Either way you go you will have one fast motor
im comparing fully built 500 hp lsx vs fully built 500hp ltx n/a, which will both then be sprayed with a BIG shot.
PCM: $60
Harness: $200, built it myself to go into the Car.
LS1 Oil Pan: $150
LS1 Steering Rack: $50
LS1 Accessories & Brackets: $250
LS1 Starter: $110
LSX Conversion Mounts: $40
And if you go LS, you will have to put a Tranny behind it, I assume you are planning on a different Tranny anyways..
Yes there is an extra cost, but the way I look at is I have what I want, and I'll never have to try and sell my LT1 Camaro to buy an LS1 Camaro..I saved a **** ton of money in the long run.
And I get to laugh at the people I know with the $20K+ LS1 Car that can't mod them cause they can't afford to, they are stuck with payments. I have about $22k in mine, it's paid for, and it'll whip a $80K C6 Z06..
PCM: $60
LS1 Oil Pan: $150
LS1 Starter: $110
IMO it's not worth the money to swap in an LS1. Build the LT1 right and it's a great powerplant.
