Brake tell tale open
Old Nov 13, 2008 | 05:27 PM
FAD2BLK93's Avatar
Default Brake tell tale open
Can anyone help me with this code please? what is it and how do I fix it. thank you.
Old Nov 13, 2008 | 05:36 PM
xx_ED_xx's Avatar
What code?
Old Nov 13, 2008 | 05:39 PM
James Montigny's Avatar
Disengage the parking brake and close the trunk
Old Nov 13, 2008 | 06:15 PM
jarretthise's Avatar
take the canuter valve off the tranny...it will help you out alot!!! it helped me out so give it a try!!
Old Nov 13, 2008 | 06:57 PM
HottestZ28's Avatar
I also heard that if you polish your tailpipes it makes them flow so much better
Old Nov 13, 2008 | 08:24 PM
Formula350's Avatar
Kanuter*, but I've actually heard if you add a second one, that you relieve the stress on the first one which then helps bypass any back pressure caused.
Reminds me of a great story I read, if I can't find it, I'll post up what I can remember.
W00T Found it
http://audiforums.com/forum/showthread.php?t=80267
Old Nov 13, 2008 | 08:41 PM
W00T Found it
Old Nov 13, 2008 | 08:45 PM
haha my bad.....i misspelled it....yea add a second one man.....it will flow sooo much better if you do lol
Old Nov 13, 2008 | 08:53 PM
W00T Found it
omg i read that....what a freakin tard man!!! hahahahaha...lets all do this and maybe it will prt out our intakes!! hahahahaha
you all should read this
Old Nov 13, 2008 | 09:03 PM
Formula350's Avatar
I'm glad you guys like it. I STILL get a kick out of it.
There's two ways to look at this: The dude really did it, and in that case it serves him right. The dude made it all up, and in that case someone sign him to work on a comedy TV show as a writer heh
In all honestly, I'm thinking more the former than the latter :S
And screw porting out valves, I'm just going to not RUN valves!!! I'll think of some way to make that work... just you wait! >_>
(Actually, as sad as that idea is, making that work, and work better than current intake and exhaust setups wouldn't be that hard to design! I have way too many crazy ideas, that if I had a way to make a prototype, I honestly think most of them would work out heh)
Old Nov 13, 2008 | 09:31 PM
it was pretty funny yes
Old Nov 14, 2008 | 11:13 AM
FAD2BLK93's Avatar
On my mac scanner it is code 81. The ABS inop light will flash at me and not stop until I clear the code. The hatch release button stopped working...I can hear it clicking under the dash but it wont pop the trunk, anyone have an idea on how to repair this one also? thanks.
Old Nov 14, 2008 | 01:27 PM
Formula350's Avatar
Unless you get that converted to a GM DTC (Diagnostic Trouble Code), I can't really help :\ Then again, you have a 93, so it might not be the 4 digit ones PCM's give out.
All I dug up was this heh
81 Trans 2-3 shift solenoid circuit
