foglights bulb change
Old Nov 13, 2008 | 10:35 PM
t/afrom504's Avatar
Default foglights bulb change
whats the easiest way I can change out the fogs???
Old Nov 14, 2008 | 12:55 AM
camerory's Avatar
You need to take off the black plastic under-cover on the front bottom of the bumper. Take off only the side you need to replace. Then unbolt the fog light from the back side to give you accesss to the bulb. Remove the electrical connector and turn the bulb counter clockwise to remove. Install the new bulb, turn clockwise, plug in the connector, install the two bolts that secure the fog housing, replace any bumper components and you are done.
Old Nov 14, 2008 | 08:09 AM
Mattsz28's Avatar
You can take the fog light out the front too, but it can be a pain. Careful to get it back to were it was before. I just count the turns.
Old Nov 14, 2008 | 07:44 PM
t/afrom504's Avatar
ok now it sounds easy
