ac question
Old Nov 13, 2008 | 11:39 AM
EliteCamaro94's Avatar
Default ac question
Hey guys just wanna know if the ac compressor in a 94 a4 camaro is any different from a 96 camaro. Also does it matter if the car is a4 or m6? a guy at the shop i went to said there is a difference but i dunno if he was correct on that so if anyone knows can you let me know. thanks
Old Nov 13, 2008 | 02:33 PM
k looked around myself and i guess it is different for an m6 and a4. So now the new question is, how hard is it to change the ac compressor? anyone have a write up or anything or will my chilton book get me through it? i havent looked in it to see if it covers ac stuff so ill have to look tonight when i get off work. So anyone give me any pointers on doin this. thanks
Old Nov 13, 2008 | 04:03 PM
wow nobody all day?????
Old Nov 13, 2008 | 04:10 PM
FlamingChicken's Avatar
should just be get the refrigerant out, unbolt lines, disconnect and unbolt compressor. you should put the system under a vacuum then recharge it afterwards. pretty straight forward.
Old Nov 13, 2008 | 04:25 PM
iceman15's Avatar
I thought that all the compressors were the same for 93-97 LT1s
Old Nov 13, 2008 | 04:35 PM
they are the same but if you have an automatic tranny then the ac compressor is different compared to a car with a manual tranny. I just found that out today.
Old Nov 13, 2008 | 06:07 PM
jarretthise's Avatar
how are they different?? its easy there is like 2 bolts holding it on...and then 1 bolt on the back of it holding the line place...its really easy to do but its a b i t c h getting your hand up in the back...maybe be able to take the alt off and go from the top to make it easier but i doubt it...worth a try though sooo
Old Nov 13, 2008 | 07:27 PM
i dunno whats different but thats what the mechanic says and on the checker website it lists two different kinds. ONe for an auto tranny and one for a manual. so i dunno what the real difference is.
Old Nov 14, 2008 | 09:31 PM
$O$OE's Avatar
my 93 compressor is not the same as my cousins 97, and both cars are A4's
