Leaking coolant, where from?!
form the rush of fresh (and colder) fluid flowing by the sensor.
The idea being to let coolant start flowing so you can displace air pockets.
You can wait for the fans to turn on, assuming the PCM is configured to turn then on at a high enough temp. The end result would be the same.
put it on the ramps, NO leaking. what the hell man. no leaks? it was WAY up to tempature. why is it not leaking now? It was draining like crazy last night. I opened the radiator cap and there was fluid right there on the top.
I took these pictures...
it looks like it might be coming from this thing attached to the radiator with a wire on it?( where my finger is pointing)
Also are these wires aftermarket?
and what is that new shiney metal object behind these pulleys?
most of the people iv seen have a rad start leaking all of the sudden have had another problem that caused the rad to start leaking....This other problem I speak of is a blown head gasket. The compression leaks out of the cylinder and into the waterjakets, therefore pressurizing them much more than they are designed to handle... the excess pressure blows out the weakest part of the cooling system,( the plastic housing of the radiator).
The easiest way to eliminate this as a possability, is to have a friend or relative rev your engine as you monitor the engine bay... You will notice the antifreeze shooting out of the radiator as the engine revs. If you do not see any squirting coolant, then this is not your problem.
I would replace the t-stat and bleed the coolant maybe even flush the sysyem. And then keep a close eye on it
Thanks!
The AC Condensor just sits in grooves on the Radiator, you can pick it up out of the grooves and keep it away, and pull the Radiator out.
