Installing the rag joint eliminator...
Remove the two 7/16th bolts. get under the car and use a piece of wood to lightly hit the bottom of the shaft with a hammer. the bottom part will come right off.
as far as an alighnment you should not need it for the parts you are swapping they are fixed points
It is between the joint on the right and the rag joint eliminator on the left. This particular one looks to be welded but your shouldn't be, just pull apart right here and it will adjust longer and shorter.
If it doesn't come off easily and you haven't done it before, your choices are to give up or try something else. If it's rusted on there quite a bit, then you can do what I suggested and it will work. Especially if you're doing it by yourself. Having taken all that stuff down before (Long tube headers install, replacement of cylinder lock, replacement of ignition switch, etc), it takes me about 5 minutes of actual work to get that steering mast free for this effort. The time saved in aggravation and cursing is well worth it, IMO.
I actually used my own hardware. I didn't really care for the long bolts and double nutting, so I got shorter bolts, used prevailing lock nuts, and locktite. If I could, I would tack weld the nut to the bolt.
