vibration that just wont go away.
Old Jan 31, 2009 | 01:17 AM
  #41
ElkySS's Avatar
im sure its possible and it scares me every time that thing starts vibrating but it hasnt hurt anything yet. i do plan on replacing that bushing but i just dont have the time or money right now
Old Jan 31, 2009 | 01:13 PM
  #42
leadfoot4's Avatar
I chased a vibration for a long time after I installed 2-3 parts on the car at the same time. Turned out it was an incorrect pinion angle. I messed with it several times, finally watched the BMR video, and followed BMR's instruction. Vibration disappeared immediately afterward.
Old Mar 3, 2009 | 01:06 PM
  #43
Jimmard's Avatar
I found my vibration for those who are still struggling. It ended up being that my brand new moser 9" housing was bent. 125 dollars later I had all new seals and no vibrations
Old Mar 5, 2009 | 02:34 PM
  #44
98cherrySS's Avatar
Where was it bent exactly? How did replacing the seals help the problem?
Old Mar 5, 2009 | 05:13 PM
  #45
ThoR294's Avatar
where is that BMR video you are talking about? ive got the same vibration also...
Old Mar 5, 2009 | 10:57 PM
  #46
redhotSS's Avatar
Same problem. Thought the same with the tailshaft bushing. When I rebuilt my other T56 I ran a rockland no walk bushing...still didn't go away. Thought it might be a bent axle or something in the rear so I swapped it out with a spare. Didn't fix a thing. Had a new yoke, u-joints, and driveshaft balanced. Still same problem. I am lowered with the stock torsion bar. I'm gonna recheck the pinion angle once I get my 383 build and back on the road.
Old Mar 5, 2009 | 11:10 PM
  #47
7.0 camaro's Avatar
ive seen aftermarket ring gears cause some vibrations. not sure if this is the case or not. but its one thing that has not been said.
Old Mar 6, 2009 | 03:50 AM
  #48
Jimmard's Avatar
The housing was bent. Not the axles, nothing internal, just the entire housing was bent. They straightened it and replaced the seals that were leaking. All replacing the seals did was stop the leaking, but I think they were eaten up because the housing was bent.
