What lifters do i need???
Old Nov 24, 2008 | 09:45 PM
nirvana1221's Avatar
Default What lifters do i need???
im going to be running a gm 847 and i was wondering what would be a good lifter, i have a stock lt1 with 104k on it and i think its time to upgrade them
Old Nov 24, 2008 | 09:47 PM
bombebomb's Avatar
Well, you can inspect the stock one's and reuse.
Or since your asking about newer one's, LS7 lifters.
Old Nov 24, 2008 | 10:26 PM
the_merv's Avatar
Veteran: Air Force
LS7 Lifters, a little over $100 for a set.
Old Nov 24, 2008 | 10:41 PM
StealthFormula's Avatar
LS7's and they are the new replacement LT1 lifters.
Old Nov 25, 2008 | 12:20 AM
iceman15's Avatar
Yea definatley use the LS7 lifters, you should also check your pushrod length. There have been alot of discussion on whether the cup in the lifter sits higher or lower than the stock ones. Whether or not its true you should still check it.
Old Nov 25, 2008 | 08:45 PM
how do you check for the right pushrod length???
Old Nov 26, 2008 | 01:15 AM
I8ASaleen's Avatar
A measuring tape or a caliper
Old Nov 26, 2008 | 09:30 AM
Elliott's94Z's Avatar
+2 on the LS7's!
Old Nov 26, 2008 | 09:53 AM
AChotrod's Avatar
with those miles I would change them to the LS7s also.
Old Nov 26, 2008 | 09:57 AM
camar0corey's Avatar
Good on you for changing them while you are in there, I had one let go that had only 85k on it. I guess lifters are weird though, my stock motor has 167k on it, never had any valve train issues.
