thermostat ??
Old Nov 24, 2008 | 11:42 PM
reaper97's Avatar
Default thermostat ??
ok i need to know what kind of thermostat i have either a 160* or 180* in my car. what should me temp be reading in my car if i have 160*? i never changed it since i bought the car and the previous owner did few mods to the engine... thanks
Old Nov 25, 2008 | 12:15 AM
tspence45's Avatar
I've got a 160* and it's also tuned for it. It usually runs right around 170*. In stop and go traffic, or if it's just sitting for a little while, it'll creep up to around 180*, or so.
Old Nov 25, 2008 | 01:10 AM
bombebomb's Avatar
Mine runs on the first mark. 160 t-stat, maybe even a shade below first mark.
If its really important, just pull it out and look.
Old Nov 25, 2008 | 01:12 AM
reaper97's Avatar
mine sits a little under the second mark what thermostat do u guys think i have on?
Old Nov 25, 2008 | 05:16 AM
reaper97's Avatar
anyone else???
Old Nov 25, 2008 | 06:08 AM
the_merv's Avatar
180*.
Old Nov 25, 2008 | 07:27 AM
dlk1950's Avatar
I have a 160, , stays about 1st line all the time,
Old Nov 25, 2008 | 10:01 AM
Elliott's94Z's Avatar
Mine with the 160 stat sits right at 165-170..never seen it creep any higher
Old Nov 25, 2008 | 10:18 AM
SoxXpupPeT's Avatar
my dads 95 caprice runs a 160 thermostat. thing never gets hot. it stays just off the cold line
Old Nov 25, 2008 | 01:17 PM
nik1703's Avatar
with a 160 degree wouldnt that cause you to run rich if you're that cold? Im around 220 most of the time and i have a stocker.
Old Nov 25, 2008 | 02:56 PM
reaper97's Avatar
Originally Posted by the_merv
180*.
Tanks
Old Nov 25, 2008 | 03:20 PM
Bad_tx_Z28's Avatar
hell, i have a 160 and in stop-n-go traffic mine will get up to the halfway mark, and then cool back down when im going. Is that normal?
Old Nov 25, 2008 | 03:37 PM
OVA1's Avatar
Keep in mind that I live in SW FLA... When I first got the car, it had a stock unit and ran HOT... I couldn't BELIEVE it when I read that the engine was designed to run at 220 degrees for emissions.
The problems began when the fans stopped coming on... which meant that when I was underway it ran around 180-200, but when I hit traffic, it would quickly climb quickly to the nervous zone.
Around that same time I started taking her to the track and found out that a cool to cold Z28 is appreciably faster than a warm to hot Z28... I yanked the therm entirely and put the fans on a switch...
I wouldn't recommend this for you artic dwellers, but I run my Z between 160 and 170 and I race her at something south of 160... I found that ten degrees equates to a tenth in the 1/8th for us... (now this is 160-180, I've never had a slip available in street runs where I was running over 180...) FYI: Our track is roughly sea level.
Old Nov 25, 2008 | 04:12 PM
Bowtie_Aaron's Avatar
stock fans come on at 226 231 i belive it, or 221 226
i run a 180 for the winter with the fans tuned to come on at 185.
summer i run a 160 with same fan setting. in heavy traffic the fans turn on, but while cruising it runs about 165ish.
no tune tune for it though, wish i did..
but even with the 180, i dont build any heat, so i have to try and figure out what is wrong.
aaron
