Heavy braking = stall?
Old Nov 26, 2008 | 01:01 AM
96blackta's Avatar
Default Heavy braking = stall?
I was testing out my brakes in the rain today by pressing on them pretty heavily, and right before I came to a complete stop, the car sort of shuddered and died. I was able to put it in park and start back up no problem though. Thoughts?
Old Nov 26, 2008 | 01:02 AM
streetassasin's Avatar
how much gas was in the tank?
Old Nov 26, 2008 | 02:25 AM
96blackta's Avatar
Full or close to it
Old Nov 26, 2008 | 05:24 AM
Smokinlt1's Avatar
sounds like the vacuum used by brake booster. I've seen where it will bring idle down just a tad but never actually cause a stall. Might want to check and see if you got any vacuum leaks or listen for hissing coming from the booster. This is just a guess without actually seeing it for myself.
Old Nov 26, 2008 | 08:35 AM
Black94Z28's Avatar
I had that happen to me in a carb 355 89 Camaro that i used to drive. I figured the sudden stop prevented the fuel from getting to the engine? Not really sure to this day what happened either, but i know exactly what your talking about.
Old Nov 26, 2008 | 10:19 AM
AChotrod's Avatar
I had a beater that did the same thing also, if you turned the wheel all the way it would die too????LOL!
Old Nov 26, 2008 | 12:26 PM
ryle's Avatar
I have the same problem, Subscribing in hopes of a fix.
Old Nov 26, 2008 | 01:53 PM
ss.slp.ls1's Avatar
^^^+1
Old Nov 27, 2008 | 12:47 AM
96blackta's Avatar
What would it tell you if I disconnect the booster hose, and the car dies?
Old Nov 27, 2008 | 01:26 AM
Sgt. Spuds's Avatar
Shirley Temple Drinker
^ nothing, every one of our cars would die if you unhooked the booster hose..
My caddy does this also... I bout plowed through a group of young African Americans the other day, noticed them at the last min and slammed on the brakes, slid to a stop and car died, I started the car back up and heard some giggling from the tribe so I rolled my window down and threatened to bust some caps...
Sgt. Spuds's Avatar
Old Nov 27, 2008 | 01:55 AM
the_merv's Avatar
Veteran: Air Force
Vacumn leak..
