Cuts out or off whenever it wants to..no codes??HELP
For those following the progress of my LT1 woes here's the latest. It started this morning and idled..I d/c the MAF and tried to drive it. No go. Died 100 feet out of the driveway. So I reconnected the MAF. Same result. When it does run it pulls strong and sounds good. When it doesn't, it doesn't hit a lick..other than turning over fine. I've ohm'ed the opti connectors and it tested good. I can't even keep it idling now long enough to shake cables and connectors looking for a problem. Still no check engine light either. Suggestions??
It came from "all ignition" off ebay. I really didn't want to think about the distributor again, but you might be right. Just trying to eliminate everything else first...especially since I just put this one in. I bet it doesn't have 500 miles on it.
Just get a genuine AC Delco or Delphi opti and call it a day.
Since I feel I've exhausting my trouble-shooting options I've submitted a request to the vendor I purchased the opti from (Oct-08 less than 500 miles on it) for a replacement unit. We'll see what happens.
They offer an ac delco/delphi upgrade, don't you think that would be a better investment? I just don't have another $250 right now. The one I had was a $129 unit off ebay.
#33
I'm not sure if you were aware of the other threads on this board relating to "All Ignition" opti problems, but these were from a few months back. If you already knew about the problems ignore my post.
https://ls1tech.com/forums/lt1-lt4-m...on-buyers.html
https://ls1tech.com/forums/lt1-lt4-m...ease-read.html
#34
Damn! I wish I had known. I called them and got a RA #, but I may still just get one from "thepartsladi" instead. I hear good things about that supplier. Lesson learned I guess, we'll see what happens. Thanks
#35
I've decided to trash the all ignition unit after all the horror stories and I just ordered a NEW OEM unit from thepartsladi. Spoke them on the phone, very helpful and should have it Friday, also ordered a new opti harness ($29) since my orginial had a broken clip at the opti. Wish I had never seen the all ignition unit...live and learn..
#36
#38
Just wanted to update my thread. I ended up getting a new delphi (OEM) opti from thepartsladi. I called those guys and explained my problem and they were very helpful. Got the opti really quick. Also ordered a new opti harness for good measure. After install it is running perfectly, so I'll keep my fingers crossed. Many thanks to those who responded for my plea for help!
Word of advice: Do your research before you buy anything! I pretty much wasted about $200 bucks on a piece of s$%t opti before I saw the light. not to mention all the downtime and wrench time...
Hope this helps somebody.
#39
