lt1 in a s10 performance upgrade
So you say do the posi, the 4.10 gears and get the traction bars and that should be good to go? The only reason i was considering the cam upgrade is due to two things, one the rear main seal has a minor leak, so that needs to be replaced and two, my headers ceramic coating is just flaking off, so i need to hve them redone, free of charge of coarse. And also, my truck is reading ''both o2 sensors are reading lean. Would you say that would be b/c i never retighened the header collector bolts again after i let the truck run a few days and it might have loosend up a little to let exhaust gases out? Or do yo uthink its the o2 sensors are bad?
The guy who did the swp is worrying that its the placement of the o2 sensors that we put them in, but the thing is we put the driver side in exactly where the o2 sensor was on the orig. Y pipe, and the passneger side, we actually did closer than the camaro had it. So i dont think the o2 sensor placement woudl be it, right?
catback would give a decent gain. its probably the bottleneck in the system now being single 2.25"
a cam would really wake the LT1 up. check the stickey for stock head / bigger cam guide.
Any ideas about the codes i am throwing?
ya appearantly if its the flex fuel 2.2 than supposedly is a very good fuel system for the lsx swap. So good luck.
long tubes in this truck are a bitch to fit. I dont even want to go through the trouble to make them fit. But yes true duals are a definate. That i can say, loll
Did you get a dyno sheet with that hp/tq increase bc that would be so bad *** to get.
And yes, i am getting it manderal bent.
And man u are generous to say low 12s, high 11s....i dunno man the truck does wiegh about 2800-3200 depending on each truck, never wieghed my truck but thats the norm. I do know that the truck wieghs a few hundred lbs less than the camaros, so whatever you ugys weight, a few lbs less.
And as for the power, its a 275hp stock motor. Than with the ported intake, the k&n airfilter, shorty headers, msd wires, and true dual manderal bent exhaust, you would say i should geta extra __HP?
6" round universal mufflers by Magnaflow. With the mods in my sig I have run 12.86 et and my car weighs 3900#. At 2800# it would be like 11.8x
What woudl you all say is the best DR's to get for the money? And the widest i can go with the iroc 16x8 wheels? I dont want to go too tall, i would like to keep it below 26.5 or below in diameter. I have 255.50.16 on mine now, so i was gonna just do the same size unless i can get a wider tire for around the same diameter.
