New Vlavetrain = burning oil
https://ls1tech.com/forums/lt1-lt4-m...tall-pics.html
it was the first time i ever did a swap like that and i didnt know. nor was told about having to change Valve Steam Seals and i think its letting oil into the engine because theres a bit of blue smoke coming out of the exhaust all the time. i reused the old ones but they looked ok to me. could anything else be the cause of the burning oil ? i really dont want to pull it all apart again to change them out but if i have to i have to. any advice would be appreciated
Good Luck Dude
Good Luck Dude
http://store.summitracing.com/partde...5&autoview=sku
there the right part number through rockauto.com im still kicking myself in the ***
:b ang:
thanks for the replys guys! Trending Topics
this was the first time i did this tho so now i know The Best V8 Stories One Small Block at Time
ill do one side at a time when the new seals come in hopefully monday. i just want to drive the car so bad! extre oil killing spark plugs, O2 sensors, clogging cats (if you have cats) coating walls of exhaust with oil residue, etc.
Oil has a REAL low octane rating and will lead to detonation causing more wear and abuse to rod/main bearings
Definitely tear it down and repair ASAP.
Lloyd
Lloyd
