Broke sypder plate, which lifters?
Old Nov 28, 2008 | 12:16 PM
strkedltweezy's Avatar
Default Broke sypder plate, which lifters?
Well had just got my car done and was driving it trying to break in my engine. But it started to misfire and started clicking, i thought one of my rockers was loose but they were fine. Removed the intake and found that my "spyder Plate" was broken on two cylinders so i spun 4 lifters and ruined my cam. Now my question Is there a better type of lifter or something else to do away with the spyder plate? What would ya'll suggest?
Old Nov 28, 2008 | 12:27 PM
impaled's Avatar
what cam, lifters, rockers, etc. did you have in there? stock heads?
Old Nov 28, 2008 | 12:28 PM
SoxXpupPeT's Avatar
you could get a stock one from SUMMIT or you could get aftermarket roller lifters that hold themselves straight. THIS is just an example
Old Nov 28, 2008 | 12:30 PM
cc306, stock lifters, afr heads, 383 bottom end, with stock syder plate and retainers, 1.6 pro magnum rockers.
Old Nov 28, 2008 | 03:10 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I have an extra stock lifter spider I'll sell you for $15 + shipping if you want to get it running real quick.
Old Nov 28, 2008 | 04:30 PM
FlamingChicken's Avatar
im running morel link bar lifters for that very reason. except i didnt catch my spun lifters as soon and ruined the motor. the lifter part number says 4602 on my estimate from Ai and they were 469/set
Old Nov 28, 2008 | 07:09 PM
1redta's Avatar
Default re
GM sells the spider at the stealership Think it is 70 something.
I had the same thing happen just put the new one in and ran it with some LS7 lifters. Too bad we can't run LS1 style lifters and retainers.
Old Dec 1, 2008 | 08:56 PM
yeah thats what i was thinking of doing but i just dont want it to happen again.... but hey its drag racing **** happens anyways. yeah not really in a hurry but i appreciate the offer. Still have to order my cam from AI hoping to gain a little more hp cant wait though
Old Dec 1, 2008 | 09:25 PM
ulakovic22's Avatar
Only way to do away with the spider is to get link bars. Other than that just get a new spider and keep on racing. I do find it weird thought that the spider broke, there isn't any load on it, all it does is hold the retainers down. What all is broken? Did something else break first and cause the spider to break?
Old Dec 2, 2008 | 06:41 AM
not sure in the OPs case but in mine it just looks like fatigue of the arm. it was bent up a bit causing minimal pressure on the dogbone. then the lifter spun in its bore bc the dogbone wasnt able to hold it straight. i was turning around 7k rpm pretty regularly though.
Old Dec 2, 2008 | 08:27 AM
TwoFast4Lv's Avatar
I would(and do) use Morel Link bar lifters
Old Dec 2, 2008 | 12:10 PM
T/A KID's Avatar
I run Morel's too, not need for any spyder trays.
Old Dec 2, 2008 | 08:14 PM
nope all that broke was the plate it looks like it was just worn out..... i just hate to put back together and the same thing happen when i race it
Old Dec 2, 2008 | 08:17 PM
What length pushrods do u use?
Old Dec 2, 2008 | 09:09 PM
TwoFast4Lv's Avatar
7.250 IF I remember correctly. I might be running +0.100 valves also
