rear end out of line?
PS I actually think when you have a solid axle it's not even called Toe but rather thrust angle but either way hope this helps
This is what is more than likely going on. Ive been doing alignments for nearly 3 years now, Done several camaros, since I owned 3 at one time.
Thrust angle more than likely is what he told you was bad. Look at the picture, thrust angle can be changed with adjustable LCA's. Now you said it was out 21 degrees, thats bad, but not terrible. The worst ive seen is 36 degrees. The only thing its gonna bother is that it may cause a slight pull.
My wifes 01 is out just a little bit and has a slight pull, Id say the sportlines, relocation brackets, and her pounding potholes prolly caused this.
