The Big Suck
You need to replace the cannister and clean the vapor line out to repair it or bypass the EVAP all together. If you do bypass it, you will need a venting gas cap and be prepared for it to smell gassy like a 60's car.
If I am to understand what’s being said here, the EVAP system is supposed to draw air & vapors out of the tank. If this is the case, OK, it seems to be working as shown by the vacuum the tank has when I open the cap, but how or where is air supposed to go into the tank to replace what the EVAP system is drawing out at the other end?
Thanks boyz....
It's also all dependent on how long between cap removals, if I fill up just a few gallons one day, and then a few more days later, it's not too bad. However, like with my DD, it's around 2 weeks before I fill up again, so it's quite the build up of pressure. With that said, and me experiencing pressure in many vehicles, I'd say that something is a bit odd with your car Paul. I say that only because you have to factor in not just the expanding vapor from the fuel, but that it is a vacuum being created (as you're adamant it is). So you have something that's pulling LOTS of gas (as in air, not fuel heh) out of your tank. Since we have metal tanks, do you have a 'pwomp' when you open it up, from the metal popping back into place? My Jeep does that, but it's from the opposite effect, since it's being pressurized, it's expanding the tank's sides, and they're then popping IN due to pressure rather than OUT from vacuum.
On the other hand... I do have a vague recollection of high volume pumps doing that, but I don't see a mention of one in your sig. Do you have one, and it's just not listed?
I’ll play with this tomorrow. After I fool with the new headliner. And fix the right window. And fix the rattle in the front. And look into the airbag light. The list never ends, does it?
If its a sucking problem as described, I would imagine that the EVAP is working and there is a clogged vent not allowing outside air to enter the tank to replace the air being extracted again by the EVAP. The vent is a white looking thing about the size of a golf ball in front of the tank.
http://shbox.com/1/fuel_pump_wiring.jpg
