Your opinion here
Old Dec 10, 2008 | 10:41 PM
Bad Lt1 Camaro's Avatar
Default Your opinion here
So me and basically everyone iv talked to around town have all told me different answers. Im going to change the plugs and wires on my LT1 but do i have to change the opti? I have got alot of yes/know answers to this question. Also do you have to remove the water pump to get to the opti. I hope this debate ends here. =)
Old Dec 10, 2008 | 10:49 PM
oifish's Avatar
If you are just replacing the plugs and wires you dont have to replace the opti. If you want to replace the opti, yes you will need to remove the water pump
Old Dec 10, 2008 | 10:51 PM
oifish's Avatar
p.s. I want your wheels
Old Dec 10, 2008 | 10:52 PM
lt1z28camaro's Avatar
The debate ended there^ lol.
Old Dec 11, 2008 | 05:51 AM
bombebomb's Avatar
Yes it did.
I was expecting something like
What kind of plugs to use? NGK tr55s
Or what kind of wires to use?I used MSD
Old Dec 11, 2008 | 06:35 AM
Badazz 97 TA's Avatar
while the tr55's are nice, they are a copper core meaning that they will wear out ALOT faster then a regular plug.
Old Dec 11, 2008 | 06:42 AM
bombebomb's Avatar
How often would you recommend changing them?
Old Dec 11, 2008 | 06:59 AM
$O$OE's Avatar
i change mine every 3k or so....thats because i get my plugs for free..
Old Dec 11, 2008 | 07:06 AM
the_merv's Avatar
No you don't have to change the OPTI.
Yes you would have to remove the Water Pump to get to it.
Old Dec 11, 2008 | 08:42 AM
Smokinlt1's Avatar
I've got 2yrs and about 15,000 on my TR55s. She still drives fine and just recently ran a personal best. I normally change them once a year. She'll have new ones by the time the track opens back up.
Old Dec 11, 2008 | 09:07 AM
Elliott's94Z's Avatar
How many miles on the Opti? You don't have to change it no. If it's pushing a lot of miles then it might not be a bad idea. "Thepartsladi" sells new Opti's at a good price. The pump does have to be removed. I've got some MSD wires and NGK TR55's up for sale if you haven't already got new wires and plugs. $50 shipped for everything. Both have 2k on them so they are fairly new. Good luck!
Old Dec 11, 2008 | 09:20 AM
baylove's Avatar
if there is nothing wrong with your opti leave it alone just change the plugs and wires and call it a day you dont want to take the opti out UNLESS YOU ABSOLUTELY HAVE TOO TRUST ME
Old Dec 11, 2008 | 11:36 AM
Iv got 104K on the opti and plugs and wires, i might be sending you a PM pretty soon for the stuff =)
Old Dec 11, 2008 | 12:01 PM
Sounds good let me know. And with 104 on the Opti you might want to consider changing it out.
Old Dec 11, 2008 | 09:53 PM
1badzee's Avatar
Mine had 148k before i changed it.. i think hes in the clear. i recommend some autolite 103's or 106's (depending if spraying or not) ive had the best luck with them and have lasted the longest. and theyre cheap as hell too
Old Dec 11, 2008 | 10:00 PM
LT1's Avatar
LT1
If its not broke why fix it?
Replace opti only if theres a problem. Its a bitch to replace not worth the trouble.
Old Dec 11, 2008 | 10:09 PM
CamaroRacing12's Avatar
x2!!!!!!!,to my knowledge i still got the stock opti in my 100k mile LT1
Old Dec 11, 2008 | 11:06 PM
well i guess its not " officially" broke but the car does seem to have a slight miss in it that continues to get worse but i guess theres no way of knowing which parts are failing
Old Dec 11, 2008 | 11:31 PM
brucealmighty744's Avatar
i don't know for sure, but could a autozone hookup tell you if the opti is in tip top shape...i hear they are free so it cant hurt, but my god some of those people that work there aren't the brightest...A 16-20 year old guy was looking up a part number for me on the computer and when he was going to show me where the oil filter was he asked "is your my trans am a 4 cylinder or a 6 cylinder"...I stopped dead in my tracks...I am 19 and even at 16 I knew trans am was only in the same sentence with 4 cylinder if you were talking about beating 1! I looked at my friend who is an f-body guy too...I said 8 cylinder, but i wanted to slap the kid. I asked the kid if he thought the K&N or the Mobil 1 oil filter was better for my car..he said "the K&N" so i got the mobil 1 since that was the oil i was using anyways lol.
